General Home Automation Structured (low voltage) wiring installation estimates
please rate
this thread
Posted by bdk on February 24, 2005, 2:32 am
I am currently in the middle of a remodel and I am adding a lot of low
voltage wiring. I, roughly, plan on having the following installed:
 29 speaker drops
 11 audio control drops
 23 cat5 or cat6 drops
 12 Bundle (2cat5/2RG6) drops
 15 component (3 RG6) drops
I recently received a bid, but I am not sure what the normal cost of
installation is therefore I cannot validate whether I am getting a
resonable estimate. I understand that I can contact a few other
installers to get bids, but I am running out of time before the sheet
rock goes up, therefore is anyone aware of any resources which can help
me to semi-accurately determine if the quote I am receiving is fair?
Thanks in advance for any help.
Posted by Robert L Bass on March 8, 2005, 12:06 pm
Why not just DIY and save a few thousand dollars?  This stuff is not rocket
science.  You and a helper (perhaps your SO) could probably prewire the
whole job in one weekend.  Cable is relatively inexpensive and readily
available.  Hardware, including speakers and controls can usually be
purchased online for a small fraction of the price an integrator may need to
charge.
Regards,
Robert L Bass
Bass Home Electronics
2291 Pine View Circle
Sarasota Florida 34231
877-722-8900 Sales & Tech Support
http://www.bassburglaralarms.com
Posted by Lewis Gardner on March 8, 2005, 1:41 pm
Robert L Bass wrote:
He is looking at 90 drops. More than a weekend project for DIY.
Posted by Robert L Bass on March 9, 2005, 2:35 pm
Two people could still do it in a weekend.  The trick is to plan everything
out before starting.  Pull multiple runs together wherever possible.  Mark
both ends of every cable as you go.  I like to bring a checklist showing
every drop for each room and mark them off as I go.
Regards,
Robert L Bass
Posted by Lewis Gardner on March 10, 2005, 3:04 pm
Even with planning it would be a killer weekend. Without planning it
would be a disaster.
90 drops X 20 minutes per drop = 30 hours
20 minutes per drop is quite fast (even for pros) since for each drop
you need to:
1. Locate and mount a box or mud ring (for speakers 3 wire end points).
2. Drill holes. At this speed spade bits and consumer drills won't cut
it. You need auger or self-feed bits, a stout drill and heavy duty
extension cord.
3. Pull and label cables.
4. Fasten cable bundles so the won't be damaged by other trades.
Not included in the above 30 hours is time to set up and get out twice
since you can't do all the work in one day. Getting all the cable and
tools in and out will eat up at least 1 hour per day. So you are looking
at two 16 hour days. My guess is that few DIYs are able to pull off such
a feat. I cannot think of any I have met that could do it in two 16 hour
days.
I just reviewed a actual time spreadsheet from a job where everything
went well. There were 55 drops which took 18 hours - 19.6 minutes per
drop. This was with a crew of three. For the actual pull one man was on
the spools, one man on the end of the wire and one man in the middle to
make corners. This was as fast as I have ever wired a traditional solid
beam two story house with basement. We were rolling.
In construction with open wood trusses the only drilling is to penetrate
floors. In one of these I used three cable joes (but no helper) and I
ran 21 drops in 10 hours which is 28.6 minutes per drop. Not bad...
 > Mark both ends of every cable as you go.
You really don't need to mark BOTH ends if you have as list or drawing
identifying the non wiring closet endpoints. If you mark the wiring
closet ends that is sufficient to maintain order.
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
Structured (low voltage) wiring installation estimates bdk 02-24-05
Related PostsForumDate
Low voltage wiring - NEC question General Home Automation 2005-09-06
Security cameras installation Service for the Greate Los Ang... General Home Automation 2009-08-19
Security camera system installation Service for the Greate L... General Home Automation 2009-08-19
Home wiring [Telecom] General Telecommunications Forum 2008-12-29
I do low voltage demo in office buildings at .25 cents a sq ... CCTV, Alarms and other Physical Security 2006-11-30
STRUCTURED wiring box? Home Automation 2004-11-17
high voltage home runs? General Home Automation 2005-03-14
Does having multiple RJ45 jacks degrade the Internet sig... Wireless Networking 2011-12-25
Wall Street's low-ball iPhone estimates bump into reality [t... General Telecommunications Forum 2012-01-06
Installation/wiring manual for Menvier TS400 Electronic Security in UK 2011-03-14
A question about CO wiring [telecom] General Telecommunications Forum 2010-12-07
Cabling and Wiring Cable Modems 2010-10-26
Google residential Gb fiber installation v1 [telecom] General Telecommunications Forum 2011-08-10
Startalk 180 wiring connection Nortel Networks 2011-02-08
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Mac to VLAN mapping on Cisco switches Cisco Systems
Sality virus help how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?‏ Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
