General Home Automation Spider in the motion sensor
Subject Author Date
Spider in the motion sensor Bill Stock 09-27-07
Posted by Bill Stock on September 27, 2007, 10:40 pm
I've got a wired sensor that's been coming on all night. So I cut back the
usual suspects (trees), but still no joy. I thought it might be a spider, so
I evicted one tonight. But it seems to be doing it again.
Assuming the spider is back, any human safe home remedies for keeping
spiders out?
Posted by Frank Olson on September 28, 2007, 12:14 am
> spiders out?
It's called silicon (pronounced "silly-kon"). It comes in convenient
tubes. Use lots. :-)
Posted by Robert L Bass on September 28, 2007, 12:26 am
> keeping spiders out?
Here's what I did for many years. It worked for me. Seal the wire
and screw mounting holes with a dab of silicon sealant (bathtub caulk
works well). Cut a small piece of sponge and, while wearing
disposable gloves, saturate it with Raid or any other anti-critter
stuff. Place the sponge inside the motion detector and close the
cover. In the tightly closed space the stuff lasts for years. It
doesn't seem to harm electronics but just to be safe I keep the
sponge away from the wires and PCB.
Please note that spiders and other critters are only one possible
cause. If there's a hole in the housing, seal it to keep drafts out.
Cool (or warm) air blowing directly onto the pyrolitic transducer can
wreak havoc with a PIR.
Make certain the detector is firmly attached to a non-moving,
non-vibrating surface. The least motion of the detector appears to
the unit as though the whole world is jumping around.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Posted by Bill Stock on September 28, 2007, 8:34 pm
>> spiders out?
> Here's what I did for many years. It worked for me. Seal the wire and
> screw mounting holes with a dab of silicon sealant (bathtub caulk works
> well). Cut a small piece of sponge and, while wearing disposable gloves,
> saturate it with Raid or any other anti-critter stuff. Place the sponge
> inside the motion detector and close the cover. In the tightly closed
> space the stuff lasts for years. It doesn't seem to harm electronics but
> just to be safe I keep the sponge away from the wires and PCB.
> Please note that spiders and other critters are only one possible cause.
> If there's a hole in the housing, seal it to keep drafts out. Cool (or
> warm) air blowing directly onto the pyrolitic transducer can wreak havoc
> with a PIR.
> non-vibrating surface. The least motion of the detector appears to the
Thanks,
Not sure how a spider could get in there. There's a gasket around the lens
and a foam block around the sensor wire. Although I didn't happen to notice
the state of the foam when I had the lens off, perhaps it's hardened up with
time.
> Regards,
> Robert L Bass
> 941-925-8650
Posted by Robert L Bass on September 29, 2007, 12:59 am
> the lens and a foam block around the sensor wire. Although I didn't
> happen to notice the state of the foam when I had the lens off,
> perhaps it's hardened up with time.
I'm not certain it is a spider but they can and do get through some
really small openings. In inner city jobs I've occasionally opens a
suspect motion detector and seen half a dozen roaches scatter away.
Yick!
Regards,
Robert L Bass
941-925-8650
Similar ThreadsPosted
Spider in the motion sensor September 27, 2007, 10:40 pm
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:03 am
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:14 am
Control occupancy sensor/motion sensor using PLC July 19, 2007, 1:16 am
pir motion sensor October 25, 2005, 3:35 am
Motion Sensor on 3-Way July 29, 2007, 11:31 am
X10 Motion Sensor January 8, 2007, 1:39 am
Motion Sensor With LED's March 5, 2007, 1:59 pm
X10 wireless motion sensor recommendation October 13, 2007, 12:33 am
X10 Wall Outlet Motion/Occupancy Sensor November 19, 2005, 10:05 am
EagleEye Motion Sensor battery life? February 8, 2007, 8:46 am
control motion/occuupancy sensor using PLC [2414U] July 19, 2007, 3:25 am
control motion/occupancy sensor using PLC[2414U] July 19, 2007, 4:22 am
Control motion/occupancy sensor using PLC [2414U] July 19, 2007, 5:48 am
I have activehomepro... and an external motion sensor.. problems... help needed August 6, 2006, 7:17 am
