Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by BruceR on March 19, 2008, 5:25 pm
Please log in for more thread options control incandescent bulbs in closets off a bathroom. They work just swimmingly except for one problem: if the exhaust fan over the toilet is turned on - even briefly - one or both (usually both) of the closet fixtures will go into a "strobe" mode flashing on and off very quickly. To resolve the issue the manual switch must be turned off then back to auto for normal operation. I am assuming the fan is on the same circuit but I'm not there now to check that. Any ideas as to the cause and, more importantly, a fix? | ||||||||||||||||
Posted by J Miller on March 19, 2008, 8:34 pm
Please log in for more thread options I'd guess the switch is freaking out for one of two reasons: 1)There's noise on the power line when the fan goes on and it sends the switch into la-la land 2) the "Motion" of the fan blade is freaking out the motion sensor (you didn't mention if the sensors could "see" the fan) I'd contact Leviton on this one. There could be a way to filter the power at the fan or switches (many fans actually have a single outlet inside that the small fan plugs into) | ||||||||||||||||
Posted by BruceR on March 20, 2008, 6:05 pm
J Miller wrote: > BruceR wrote:
>> I installed a couple of simple Leviton motion detector switches each
>> to control incandescent bulbs in closets off a bathroom. They work >> just swimmingly except for one problem: if the exhaust fan over the >> toilet is turned on - even briefly - one or both (usually both) of >> the closet fixtures will go into a "strobe" mode flashing on and off >> very quickly. To resolve the issue the manual switch must be turned >> off then back to auto for normal operation. I am assuming the fan >> is on the same circuit but I'm not there now to check that. Any >> ideas as to the cause and, more importantly, a fix? >> >> >
> I'd guess the switch is freaking out for one of two reasons: > 1)There's noise on the power line when the fan goes on and it sends > the switch into la-la land > 2) the "Motion" of the fan blade is freaking out the motion sensor > (you didn't mention if the sensors could "see" the fan) > > I'd contact Leviton on this one. There could be a way to filter the > power at the fan or switches (many fans actually have a single outlet > inside that the small fan plugs into) The blades are actually hidden as it's a "fart fan" up in the ceiling and the two closets are some distance away. I'll try a call to Leviton. What's interesting is that once the flickering is triggered by the fan being turned on, turning the fan off does not stop it. It will flicker till the switch is manually reset. | ||||||||||||||||
| Similar Threads | Posted |
| Slightly OT question | March 19, 2008, 5:25 pm |
| Whole house generators (slightly OT) | October 17, 2006, 11:42 am |
| question | October 24, 2005, 11:59 am |
| HI Im New and have a question | April 25, 2006, 3:00 pm |
| Question of the day | September 28, 2006, 11:12 pm |
| X10 Camera question | February 9, 2005, 4:58 pm |
| Relays Question | February 17, 2005, 4:56 am |
| X10 Control Question | March 29, 2005, 8:36 am |
| HomeSeer Question | March 30, 2005, 12:20 am |
| Question about this product | June 9, 2005, 9:44 pm |
| General X10 question | August 29, 2005, 5:27 pm |
| Illiterate X-10 Question | October 25, 2005, 6:39 pm |
| Insteon question | November 20, 2005, 12:32 pm |
| Keypadlinc question?? | December 8, 2005, 1:55 pm |
| translator question | January 20, 2006, 10:59 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
