Posted by Robert L Bass on January 10, 2008, 6:16 pm
"Robert Green" wrote:
> This is one style of drive ring:
Thanks, Robert. Those are the same drive rings except they are 1/2"
whereas I use 5/8 or larger and their prices are a tad high.
Also, you don't really need them on every joist. That's overkill
IMO. Just place one ring every 3-4 feet and it will be fine.
I should have mentioned that the job will be neater if you bang the
nails into the corner of the joists at a 45º angle rather than
straight up into the bottom edge. That will place the ring nicely to
carry the main run while joining cables to the run with the least
bend.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com Sales & Tech Support 941-925-8650
Customer Service 941-232-0791
Fax 941-870-3252
| Similar Threads | Posted |
| Re: pre-wire home - best practices? | January 8, 2008, 7:52 pm |
| Re: pre-wire home - best practices? | January 10, 2008, 6:16 pm |
| Re: pre-wire home - best practices? | January 14, 2008, 8:22 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 6:42 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 9:13 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 7:49 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 8:36 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 7:31 pm |
| Re: pre-wire home - best practices? | January 15, 2008, 7:32 pm |
| Security for HA controllers: Best Management Practices ? | March 31, 2007, 11:29 am |
| PR: Draper Home Theater and Home Automation Products @ Bass Home Electronics | December 9, 2006, 12:59 am |
| Public posting home automation/home entertainment weblog | February 13, 2005, 9:40 pm |
| PR: Home Automation Power Supplies available at Bass Home Electronics | October 22, 2006, 8:33 am |
| Home Automation in a Alternate Home Power Environment | June 15, 2005, 3:02 pm |
| My Home Theater/Home Automation PC setup | December 26, 2005, 3:17 am |
