General Home Automation Re: leviton vizia RF switches (Z-wave)
Subject Author Date
Re: leviton vizia RF switches (Z-wave) Robert L Bass 03-16-07
Posted by Robert L Bass on March 16, 2007, 3:54 pm
> Leviton has just added an RF component
> to their Vizia line. I spoke to them yesterday
> and they said it's been out for about 1
> month.
Leviton's Vizia RF systems are Z-Wave. One
advanage there is that they are compatible
with all of the other Z-Wave systems on the
market. There are over 100 manufacturers
selling or developing Z-Wave hardware already.
> I'm replacing all my old X10 stuff (too flaky).
> I also have just redone several rooms in my
> basement, so i'm going to wire up all those
> rooms with a mix of non-RF and RF switches.
> If the technology is reliable, I'd likely get to
> work changing many of the switches
> throughout the house.
Z-Wave is reliable. Although one poster who
has not used it claims otherwise, the stuff
can handle a very large home if done right.
Leviton also makes X10 compatible units
though I prefer the RF.
> These things are very expensive ($70-$80+)
> per switch...
Prices vary depending on who the vendor is
and the volume they do with Leviton. Shop
around.
Note: I'm a Leviton dealer so I'm not entirely
unbiased.
> Although they're new, I'm wondering if anyone
> has tried them?
Although I've posted many of their other products
online, I still have to get the Vizia set up in our
database. I should have them available shortly.
I can't give you customer experience on Vizia
thoough. It's still too new.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Posted by Dan Wright on March 17, 2007, 3:09 am
Here are mine:
I have done two ViziaRF installs to date. One large and one medium.
Several others are planned in the near future. Installation is no harder
than X10 or any other retrofit. You will curse the electrician with some
regularity due to box size. Any of the HA switches are quite a bit larger
than standard ones and box space will be tight. That said, I have always
been able to make things fit...eventually.
The ViziaRF switches rock in terms of feel and ease of install and come with
a 5 year warranty. High WAF on the Vizia as well. They follow Lutron and
other high end lighting in terms of form factor. Its also being pushed as
the preferred format for the elderly. I have not used other brands enough
to comment on them.
I am yet to find a range/hops issue, even in the large installation. I
have not done formal tests, but my current attitude is that it is good
enough up through the 3500 sqft range/single story, depending on layout.
Homeseer offers a tool that does Z-wave network analysis which would help
with any network issues.. It requires their Z-troller primary controller.
Same goes for signal interference. I have set Homeseer to poll regularly
and it logs any devices that does not respond. A subset of the nodes show
up randomly and I can not tie it to household activity. However, they all
respond to polls. For now its seems to be network transients, and they are
not impacting performance. The closed loop feedback is great, especially
for anyone coming from . Even the low cost Intermatic HA09 give an
indication in case of command failure.
While there are other PC products out there, Richard Helmke still sets a
high standard for customer service and support. His efforts with the
rollout of the Leviton Zone and Wall controllers were exemplary.
I have not yet integrated Z-wave with either with HAI or Elk. I used
Homeseer with the larger installation, and no central controller (other than
the Z-wave primary remote) on the other.
The interchangeability is OK, but not perfect. There are still wrinkles in
a few areas. Creating heterogeneous secondary controllers is a case in
point.. Typical under the circumstances, but better than I thought I would
find. Cynic that I am, I was pleasantly surprised about the overall
interoperability I have found.
Asymmetric control is my big whine at the moment. Nothing out there that
addresses that yet. It can sort of be done by Homeseer, but the limitation
is fundamentally existing Z-wave hardware. I am annoyed enough by it to
consider hybriding a system with UPB or even X-10 to get around it. The
new wall controller from Intermatic may. Its in beta, and I have asked to
join that effort. Other manufacturers appear to be interested in that
functionality as well..
There are other product areas I would like to see filled. Fan speed
controller is one, fixture modules, and outlets (there is one promised from
Intermatic real-soon-now) also come to mind. A wall controller with single
switch functionality would also be very useful.
My thoughts as of tonight.
Dan Wright
Starwolf Systems
Posted by Dave Houston on March 17, 2007, 5:30 am
What's the distance between nodes? Does Vizia use 4 max hops?
http://davehouston.net
http://tech.groups.yahoo.com/group/roZetta/
roZetta-subscribe@yahoogroups.com
Posted by Dan Wright on March 17, 2007, 11:18 am
>>controller.
ViziaRF says it use up to 4 hops.
Roughly the longest distance between nodes is about 25 feet. Furthest node
from the primary controller is about 65 feet.
Posted by Robert L Bass on March 17, 2007, 11:46 am
> nodes is about 25 feet. Furthest node from the primary controller is about
> 65 feet.
I think the real point is that in applications such as yours the standard (4
hop) Z-Wave system is quite capable. Obviously, each
home is different and one 3,500 sf home might be more difficult to accommodate
than another. Some have claimed without ever having
seen it, much less tested it, that Z-Wave cannot handle larger homes at all. It
does the newsgroup a service to post real world
experience with Z-Wave and competing technologies.
Regards,
Robert L Bass
941-925-8650
Similar ThreadsPosted
Re: leviton vizia RF switches (Z-wave) March 16, 2007, 2:25 pm
Re: leviton vizia RF switches (Z-wave) March 16, 2007, 3:54 pm
Re: leviton vizia RF switches (Z-wave) March 17, 2007, 11:51 am
Vizia non RF switches January 23, 2007, 12:28 pm
Leviton Vizia Z-Wave Installation Considerations May 1, 2007, 10:51 am
Re: Does leviton make anything better than the leviton 6381 that ramps up from 0% when turned on? November 3, 2005, 9:41 pm
Vizia+ availability June 25, 2008, 12:42 am
Elk and Zwave March 18, 2007, 12:40 pm
Q: On Q vs Leviton December 3, 2006, 2:03 am
Insteon vs UPB vs Zwave February 18, 2006, 10:32 pm
Insteon or Zwave? May 15, 2006, 7:49 am
Leviton QuickPort RCA April 29, 2005, 11:59 pm
Leviton and DirecTV July 2, 2005, 12:57 pm
Leviton Intellisense Vs Others January 12, 2006, 3:03 pm
Leviton HCA02-10E June 18, 2006, 7:26 pm
