General Home Automation Re: d-day
Subject Author Date
Re: d-day Dave Houston 12-22-07
---> Re: d-day Marc_F_Hult12-22-07
  ---> Re: d-day Jeff Volp12-23-07
    ---> Re: d-day Dave Houston12-23-07
      `--> Re: d-day Jeff Volp12-23-07
Posted by Dave Houston on December 22, 2007, 7:16 am
>If candelabra-base and low voltage landscape lighting bulbs are
>included in the ban, it'll probably cost $5K to $8K to replace
>fixtures in the house I'm occupying.
There's a story in this morning's NYT that, while short on specifics,
implies that GE (and probably others) are working on replacements for
various types of specialty lights.
http://www.nytimes.com/2007/12/22/business/22light.html?ref=us
And GE had earlier annpunced it would have incandescents that will meet the
efficiency standard (30% increase in efficiency - which by a mysterious
coincidence is what Philips new Halogena bulbs offer) by the time the law
takes effect. What's not known is what the efficient incandescents will cost
but, unless they cost an arm and a leg, it will make more sense to use them
rather than replace fixtures.
>> Of course, any reduction will affect the utilities' bottom lines so they
>> will find ways (service fees, minimum bills, etc.) to recoup their
>> losses.
>They won't have to do anything creative, just apply for a rate
>hike on the grounds of maintaining their return on investment.
Another factor is "power factor". I may have missed it but don't recall
seeing anything that mandates a minimum PF for CFLs. If uncorrected, most
have PF around 60% which means the utility has to supply 1.67x as much
current as is actually used by the light. This means the green benefits are
less than face value. The higher currents (and infrastructure) do constitute
a real cost to the utility. So while a CFL will use less current, it's not
as much of a reduction as is usually claimed.
http://davehouston.net http://davehouston.org
http://tech.groups.yahoo.com/group/roZetta/
roZetta-subscribe@yahoogroups.com
Posted by Marc_F_Hult on December 22, 2007, 12:29 pm
>are less than face value. The higher currents (and infrastructure) do
>constitute a real cost to the utility. So while a CFL will use less
>current, it's not as much of a reduction as is usually claimed.
More FUD. Dave makes up the 60% figure based on the very oldest and very
worst specifications he can Google up. This is like projecting the
capabilities of current and future personal computers based on the
characteristics of a 1983 IBM-PC.
As I pointed out nine months ago in this newsgroup in
http://groups.google.com/group/comp.home.automation/browse_thread/thread/
e884c965201a543/52615a29efcdcc27?lnk=st&q=comp.home.automation+Marc_F_Hult+
cfl+powe+factor#52615a29efcdcc27
when Dave posted similar misinformation about the power factor of CFL's,
the n:Vision CFL I reviewed has a _measured_ power factor of 0.94 to 0.97
-- not 0.60 as Dave now claims.
This is not an exotic or unusual CFL. I bought this inexpensive n:vision
CFL at the Home Depot that is a mile from Dave's apartment and measured its
power factor using a Kill-A-Watt meter of the same model that Dave has
written that he also owns and subsequently recommended for this purpose in
this newsgroup.
And as I previously pointed out in
e884c965201a543/52615a29efcdcc27?lnk=st&q=comp.home.automation++Products+
(TCP)+SpringLamp+I+introduced++earlier+the++#52615a29efcdcc27
        "There are of course, higher priced CFLs with even better
         specifications and performance -- They just haven't reached
        the price point of the n:vision CFLs. .. For example, of the
        20 watt (75-watt equivalent) 2700K Technical Consumer Products
        (TCP) SpringLamp I introduced earlier the N:Vision CFL's
        discussion has a rated power factor of " >.90 "
And the very technical paper that Dave Houston introduces to use as the
springboard for his misinformation in the thread cited above
http://www.st.com/stonline/products/literature/an/4042.pdf
demonstrates that technical solutions to the erstwhile 'problem' of power
factor are well known, public ally available, and have in fact been
implemented my several manufacturers -- including a model whose actual
performance Dave could trivially verify if he actually wanted to be
constructive and accurate.
... Marc
Marc_F_Hult
www.ECOntrol.org
Posted by Jeff Volp on December 23, 2007, 10:51 am
My own observations parallel Marc's input.
Early CFLs all had large bases. I disassembled a couple over the years, and
they had a rectifier feeding a large electrolytic capacitor directly at the
AC power input. Some of those early CFLs attenuated X10 signals, but I
never saw them radiate noise in the X10 transmission window, which extends
for 1mS after each zero crossing. The early Philips "Earthlights" were
totally compatible with X10 transmissions. Unfortunately, ours are finally
wearing out after about a decade of service.
Many have reported problems with newer CFLs causing problems for X10
transmission. I wrote a report on several that radiate noise in the X10
frequency band inside the X10 transmission window. Those have much smaller
bases. While I have not yet disassembled one, it seems pretty obvious from
the radiated noise that the switching converter is running over the entire
waveform. That also allows them to eliminate the large high-voltage
electrolytic that dictated the size of the base.
To jam the circuitry into smaller and smaller bases, it is impossible to
include the large high-voltage electrolytic capacitors that result in the
low power factor numbers. The downside is that some of these newer units
with high-frequency switching supplies radiate that switching noise back
onto the powerline.
Jeff
> its
> this newsgroup.
> ... Marc
> Marc_F_Hult
> www.ECOntrol.org
Posted by Dave Houston on December 23, 2007, 12:35 pm
Jeff, I'm not at all sure what you're referring to or how your "large
capacitor" or X10 compatibility is pertinent to whether or not CFLs have low
power factors but this is taken from the Wikipedia article on Power Factor.
You can find essentially the same analysis and numbers at several other web
sites having to do with SMPS design. And, people have posted Kill-A-Watt
measurements of CFL PFs here that were in the 0.61 area. I doubt that low
cost commodity producers of CFLs are going to voluntarily increase cost by
using active PF correction. If you read my original post on this, I said "if
uncorrected", most CFLs with will have low PF - what was unstated is that
most CFLs now use SMPS and will need PF correction - I did not say that all
CFLs must have low PF.
http://en.wikipedia.org/wiki/Power_factor
<quote>
In circuits having only sinusoidal currents and voltages, the power factor
effect arises only from the difference in phase between the current and
voltage. This is narrowly known as "displacement power factor". The concept
can be generalized to a total, distortion, or true power factor where the
apparent power includes all harmonic components. This is of importance in
practical power systems which contain non-linear loads such as rectifiers,
some forms of electric lighting, electric arc furnaces, welding equipment,
switched-mode power supplies and other devices.
A particularly important example is the millions of personal computers that
typically incorporate switched-mode power supplies (SMPS) with rated output
power ranging from 250 W to 750 W. Historically, these very-low-cost power
supplies incorporated a simple full-wave rectifier that conducted only when
the mains instantaneous voltage exceeded the voltage on the input
capacitors. This leads to very high ratios of peak-to-average input current,
which also lead to a low distortion power factor and potentially serious
phase and neutral loading concerns.
Regulatory agencies such as the EU have set harmonic limits as a method of
improving power factor. Declining component cost has hastened acceptance and
implementation of two different methods. Normally, this is done by either
adding a series inductor (so-called passive PFC) or the addition of a boost
converter that forces a sinusoidal input (so-called active PFC). For
example, SMPS with passive PFC can achieve power factor of about 0.7-0.75,
SMPS with active PFC, up to 0.99, while SMPS without any power factor
correction has a power factor of only about 0.55-0.65.
To comply with current EU standard EN61000-3-2, all switched-mode power
supplies with output power more than 75 W must include passive PFC, at
least.
A typical multimeter will give incorrect results when attempting to measure
the AC current drawn by a non-sinusoidal load and then calculate the power
factor. A true RMS multimeter must be used to measure the actual RMS
currents and voltages (and therefore apparent power). To measure the real
power or reactive power, a wattmeter designed to properly work with
non-sinusoidal currents must be used.
</quote>
>onto the powerline.
>Jeff
Posted by Jeff Volp on December 23, 2007, 5:37 pm
There are many fixtures that would not accept the older CFLs without some
modification. You may remember the hoop extenders that were included with
some of the early CFLs. Most of today's commodity CFLs are physically much
smaller with bases similar in size to equivalent incandescent bulbs.
Low power factor results from a capacitor-input power supply that is only
drawing current near the peak of the waveform (which also happens to be away
from where X10 signals are transmitted). The small bases used in today's
CFLs make it impossible to squeeze in the 175V+ electrolytic capacitor
required for direct line rectification. So these newer units use a
switching pre-regulator on the raw rectified AC input. That pre-regulator
runs essentially over the entire waveform, resulting in a much higher power
factor (and also noise radiated in the X10 transmission window).
I'm amazed how cheap semiconductors have become. It may very well be
cheaper to use a switching pre-regulator than the large high-voltage
electrolytic capacitor needed for direct line rectification. The XTB filter
capacitor costs almost twice as much as the high power MOSFET used in the
transmitter output stage. It wouldn't surprise me that the pre-regulator
design actually costs less. And the smaller physical size means a larger
potential market for these commodity CFLs.
Jeff
> low
> Factor.
> web
> "if
> all
(other stuff snipped)
