Posted by Graven Water on July 4, 2008, 1:40 pm
I probably got an answer to this ... Somebody told me what you to is
connect the R and G terminals to turn on the fan. So the dehumidistat
switch would connect the R and G terminals as well as turning on the
dehumidifier. Also they told me that if there's central AC, there would
have to be a relay to avoid feeding power to the AC. I don't have AC now but I
might get it.
Comments?
Laura
Posted by ransley on July 4, 2008, 4:24 pm
> connect the R and G terminals to turn on the fan. =A0So the dehumidistat
> dehumidifier. =A0Also they told me that if there's central AC, there woul=
d
> have to be a relay to avoid feeding power to the AC. =A0I don't have AC n=
ow but I
> might get it. =A0
> Comments?
> =A0Laura
A waste of time, as I said to lower humidity maybe 20% 35% will heat
up the house maybe 3-4f at maybe nearly the same electric cost as
running whole house AC. Only if interior temps were near 68 would this
idea make sense as if you lived in Oregon. But if you are warm now,
you will get hot running dehumidifiers.
| Similar Threads | Posted |
| Want a portable dehumidifier to work with heater fan | July 1, 2008, 5:11 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 7:02 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 8:18 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 4, 2008, 1:40 pm |
| Would This Work? | March 26, 2006, 12:37 pm |
| How does Insteon work? | June 4, 2007, 9:44 pm |
| Water heater eating X-10 signal | April 16, 2007, 5:11 pm |
| For 1-2 days work, some serious HA progress | July 31, 2006, 12:38 am |
| Will IR Illuminator work with any CCD Camera? | December 30, 2006, 10:28 pm |
| LED bulbs that work with dimmers? | March 13, 2007, 7:30 pm |
| Will this work for dimming 12V Halogen? | December 11, 2007, 2:18 pm |
| Need help with some sort of wireless thermometer set up at work | February 21, 2006, 8:31 am |
| Will a Terk Leapfrog IR extender work with X10 Powermid? | August 28, 2005, 2:37 pm |
| Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... | October 21, 2005, 12:50 pm |
| Converting An Existing X10 System To Work With CFLs | February 9, 2008, 8:30 pm |
