General Home Automation Re: Want a portable dehumidifier to work with heater fan
Subject Author Date
Re: Want a portable dehumidifier to work with heater fan Graven Water 07-01-08
Posted by Graven Water on July 1, 2008, 7:02 pm
I wrote:
> I want to run a portable dehumidifier with an external dehumidistat
> (switch that goes on when the humidity is above a certain level).
> And I'd like the furnace fan to go on when the dehumidifier does, to
> circulate the air in my house so it'll dehumidify my whole house.
> The dehumidifier has to have a manual control to do this
I mean a mechanical control. My tongue got tangled, or my virtual tongue,
my fingers.
Laura
> the ones with electronic controls forget their settings when power goes
> off, or they have a capacitor so they remember the setting a short time.
> Am I right that this would be a simple thing to do? Can anyone describe
> to me how it could be done? I'd get an electrician to set it up, but
> I'd like to get an idea of how it would work.
> There are various dehumidistats around. Honeywell makes one that is
> wall-mounted and directly connected to the house wiring, also one that
> ?is an interrupt switch and plugs into a wall outlet.
Posted by ransley on July 1, 2008, 7:51 pm
> > circulate the air in my house so it'll dehumidify =A0my whole house. =
=A0
> I mean a mechanical control. =A0My tongue got tangled, or my virtual tong=
ue,
> my fingers.
> Laura
> > off, or they have a capacitor so they remember the setting a short time=
> > Am I right that this would be a simple thing to do? =A0Can anyone descr=
ibe
> > to me how it could be done? =A0I'd get an electrician to set it up, but
> > There are various dehumidistats around. =A0Honeywell makes one that is
> > ?is an interrupt switch and plugs into a wall outlet. =A0- Hide quoted =
text -
> - Show quoted text -
Dehumidifiers creat heat, mine can raise basement temp 3f. Do you have
AC. It depends on size , tightness of house, humidity level and temp
of house. If its big leaky and humid you will need a big unit that may
cost as much to run as AC and heat your home 2-5 degrees.
Dehumidifiers are best when outside air is under maybe 65. You dont
need a humidistat outside, its the inside you are doing.
Similar ThreadsPosted
Want a portable dehumidifier to work with heater fan July 1, 2008, 5:11 pm
Re: Want a portable dehumidifier to work with heater fan July 1, 2008, 7:02 pm
Re: Want a portable dehumidifier to work with heater fan July 1, 2008, 8:18 pm
Re: Want a portable dehumidifier to work with heater fan July 4, 2008, 1:40 pm
Would This Work? March 26, 2006, 12:37 pm
How does Insteon work? June 4, 2007, 9:44 pm
Water heater eating X-10 signal April 16, 2007, 5:11 pm
For 1-2 days work, some serious HA progress July 31, 2006, 12:38 am
Will IR Illuminator work with any CCD Camera? December 30, 2006, 10:28 pm
LED bulbs that work with dimmers? March 13, 2007, 7:30 pm
Will this work for dimming 12V Halogen? December 11, 2007, 2:18 pm
Need help with some sort of wireless thermometer set up at work February 21, 2006, 8:31 am
Will a Terk Leapfrog IR extender work with X10 Powermid? August 28, 2005, 2:37 pm
Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... October 21, 2005, 12:50 pm
Converting An Existing X10 System To Work With CFLs February 9, 2008, 8:30 pm
