Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dave Houston on January 29, 2007, 10:43 am
Please log in for more thread options Have you tried any of the CCF codes listed for the VPL-HS51? http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=sony&dv=projector There's only one Optoma projector listed but the codes are often the same over a range of a manufacturer's products. http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=optoma&dv=projector http://davehouston.net http://tech.groups.yahoo.com/group/roZetta/ roZetta-subscribe@yahoogroups.com | |||||||||||||
Posted by on January 29, 2007, 2:09 pm
Please log in for more thread options this. snip~ http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-FX51.pdf http://www.pronto.philips.com/library/documents/ProntoEdit %20Professi... The factory database is updated regularly. Good luck!! snip~ Frank Thanks.I was able to get the manual. I did not find the database on the pronto site. I went to the links mentioned but no joy yet. snip~~ >
snip~
> http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db... > > There's only one Optoma projector listed but the codes are often the same > over a range of a manufacturer's products. > > http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db... Dave: I had already tried optoma and only power thing partially works it only switches it off.. not on.. nothing else works. Unfortunately neither the remote central has the codes nor philips site. Sony hsf51 does not work. ;( . Btw I had been to remote central earliar.) I have written to sony & optoma people. Hope they respond. The local agent in dubai though said that he can order the remote but cost was very high about usd220 which i think is waste. But if I do not succeed than it will not be waste I guess :~). I am hoping that one of the participents here will have pronto and one of the projector along with the time.. Hope thing works I hope :--))) Thanks again. | |||||||||||||
Posted by Frank Olson on January 30, 2007, 12:21 am
Please log in for more thread options veekaydee@hotmail.com wrote:
> First I thank you both for being helpful and taking time out for
> this. > > > snip~ > http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-FX51.pdf > > http://www.pronto.philips.com/library/documents/ProntoEdit > %20Professi... > The factory database is updated regularly. > > Good luck!! > > snip~ > Frank Thanks.I was able to get the manual. > I did not find the database on the pronto site. I went to the links > mentioned but no joy yet. Your most welcome. Your "problem" sort of reminds me of the way my wife "searches" the Internet. I guess she's not the only one that's "technologically challenged". :-) Keep looking. All the info you need is at the Phillips site I provided. You can also email their tech support department if you're *really* having trouble. | |||||||||||||
| Similar Threads | Posted |
| Re: Projector sony vpl-fx51 & optoma EP 756 .ccf ir signature files | January 29, 2007, 10:43 am |
| fault in Sony VPL-CS2 projector | January 23, 2008, 3:09 pm |
| Encrypt and view images and other files in Windows | March 1, 2005, 5:50 am |
| PR: Brinks Home Security files Civil Suit against Jim Rojas & www.tech-man.com | April 3, 2007, 11:01 pm |
| Projector Comparison | May 13, 2006, 2:39 am |
| Projector Lift V.2 | August 11, 2006, 11:15 am |
| projector color bars and image commisioning | November 7, 2005, 6:20 am |
| 360 degree photo patents bought by Sony | February 6, 2007, 12:10 am |
| Wi-Fi Sony mylo Personal Wireless Communicator | June 28, 2008, 8:21 am |
| quick 1 minute survey about Sony flat panel tvs | April 21, 2005, 11:56 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>I am need of some help & this is where I hope to get it.
>I bought these 2 projectors on ebay but remotes / operating manual
>were not included. (I presumed damn! I presumed and now I have learnt
>my lesson)
>I do have prontopro Philips remote which can learn ir signatures. I
>have googled and googled but could not find ir signature i .e .ccf
>files. Could You point / help me to get this problem solved. I am also
>looking for owners manual but on the seller's site these are not there
>as these are old models.
>Thanks
