Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Robert Green on September 25, 2007, 2:02 am
Please log in for more thread options > > How do I change the speed dial for the pound (#) sign key (aka hash
key)?
Try holding down the # key for a few seconds. A prompt should appear asking if you'd like to assign a speed dial. Once it's configured, simply hold down the appropriate key for one second to call the assigned number or contact. -- Bobby G. | |||||||||||||
Posted by KCat on September 26, 2007, 12:58 am
Please log in for more thread options > Try holding down the # key for a few seconds. A prompt should appear
> asking if you'd like to assign a speed dial. Once it's configured, simply > hold down the appropriate key for one second to call the assigned number or > contact. When I hold the # key down for a few seconds, it makes the call of the number somehow I programmed into the blackberry in the first place. No matter how long I hold the # key down, it still just calls the number already programmed into the speed dial. When I look up the speed dial numbers on the Blackberry 8700, I only see A-Z and not the # sign. Can the Blackberry be THIS hard to use? Isn't anyone out there a Blackberry knowledgeable person? If I could only ERASE the number stored for the # sign, then I could start all over. Does ANYONE know how to erase the speed dial for the # sign? best kcat | |||||||||||||
Posted by Robert Green on September 27, 2007, 3:06 am
Please log in for more thread options I believe the new Blackberry allows the use of only LETTER keys to store
speed dials. This is a big step up from non-mnemonic numbers and it gives you 26 keys to assign instead of 10. But it also means that when you press # you're really pressing the speedial letter Q that comprises the bottom half of the dual purpose key. Look for the Q speedial on the list and that should be the speed dial string that's dialing your voice mail. See the keyboard layout below. You should be able to delete or edit the string from there. http://www.phonescoop.com/phones/zoom.php?h=1580&g=1 -- Bobby G. > On Tue, 25 Sep 2007 02:02:11 -0400, Robert Green wrote:
simply
> > asking if you'd like to assign a speed dial. Once it's configured, > > hold down the appropriate key for one second to call the assigned number
or
> > contact.
> When I hold the # key down for a few seconds, it makes the call of the > number somehow I programmed into the blackberry in the first place. > > No matter how long I hold the # key down, it still just calls the number > already programmed into the speed dial. > > When I look up the speed dial numbers on the Blackberry 8700, I only see > A-Z and not the # sign. > > Can the Blackberry be THIS hard to use? > Isn't anyone out there a Blackberry knowledgeable person? > > If I could only ERASE the number stored for the # sign, then I could start > all over. > > Does ANYONE know how to erase the speed dial for the # sign? > > best > kcat | |||||||||||||
Posted by KCat on September 28, 2007, 2:05 am
Please log in for more thread options On Thu, 27 Sep 2007 03:06:11 -0400, Robert Green wrote:
Oh my! You're right. I'm so dumb. That's how I set it looong ago. I didn't realize this until you said it. I set the Q key which to me was the # sign. Oh my. Can I delete my prior posts so I don't look so stupid? best kcat | |||||||||||||
Posted by Robert Green on September 28, 2007, 3:17 am
Please log in for more thread options > On Thu, 27 Sep 2007 03:06:11 -0400, Robert Green wrote:
> Oh my! > You're right. > I'm so dumb. > That's how I set it looong ago. > I didn't realize this until you said it. > I set the Q key which to me was the # sign. > Oh my. > Can I delete my prior posts so I don't look so stupid? (-: There are no stupid questions. In this case, you may have been fooled by their transition from the numeric to the alpha speed dial system. Now that I think about it, they should really offer 52 speed dial options by incorporating the shift key. I think it's a perfectly natural mistake to me. It took me a while to figure it out, too, since I haven't touched a Blackberry in quite some time. I might not have if there wasn't a glitch in the newer units that screws up the voicemail speed dial. I saw that article that made me realize what might be happening because the author wrote "When I press the 1/W key." That made some neurons click and I realized there are two characters on each key for speed dial, but only the unshifted ones appear on the pull down list. I should have realized as soon as I read your messages that # wasn't a valid speed dial number but I didn't. So don't feel bad, I'll bet many others have made the very same mistake, too. The # stands out more, visually speaking, on the key cap than the Q so it's pretty natural your brain made the morph. Glad we got it solved. -- Bobby G. | |||||||||||||
| Similar Threads | Posted |
| Re: How to change pound sign (#) speed dial on Blackberry 8700 | September 25, 2007, 2:02 am |
| programming speed dial on at&t 944 | November 8, 2005, 5:55 pm |
| Neon sign interferes with X10 signal | March 21, 2006, 7:54 am |
| How to change ASCII code to OPC | April 7, 2005, 2:37 am |
| OPPORTUNITY TO CHANGE YOUR LIFE | August 2, 2005, 10:14 am |
| DST change and home auto... | February 23, 2007, 9:53 pm |
| Jack PC "will change everything...COMPUTER ...FITS IN .. WALL PORT" | June 15, 2006, 8:57 am |
| Smarthome 1132CU and Daylight Savings Time Date Change | February 26, 2007, 12:58 pm |
| Coming Soon: Low Cost pan-only Speed-Dome | September 27, 2005, 12:01 pm |
| High speed ARM debugger & programmer | May 17, 2006, 11:51 am |
| Need speed switch for DIY funicular/hillside elevator | October 28, 2006, 2:44 pm |
| Best wireless router & cards for high-speed cable connection? | May 15, 2005, 3:59 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
