Posted by Dave Houston on July 19, 2007, 7:14 am
>Hi
>I want to control occupancy sensor [PMS02] and motion sensor [MS14A]
>using powerlinc V2 controller USB [2414U]. There is also an RF
>transceiver present in the circuit. Manually i be able to control the
>x10 PRO modules using the motion sensor/transceiver combination. The
>lamp module is LM465.
>I want to control the motion sensor/occupancy sensor using PLC but no
>idea about how it can be done
>Can anyone suggest steps [if possible]
>Thanks
>Arnie
The X-10 Pro PDF for the PMS02 gives a thorough explanation, including a
pictorial diagram of its use and application.
http://www.x10pro.com/pro/pdf/pms02.pdf
>Thanks
>Arnie
