General Home Automation Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller
Subject Author Date
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller Dave Houston 07-19-07
Posted by Dave Houston on July 19, 2007, 7:03 am
>Hi
>I want to control occupancy sensor [PMS02] and motion sensor [MS14A]
>using powerlinc V2 controller USB [2414U]. There is also an RF
>transceiver present in the circuit. Manually i be able to control the
>x10 PRO modules using the motion sensor/transceiver combination. The
>lamp module is LM465.
>I want to control the motion sensor/occupancy sensor using PLC but no
>idea about how it can be done
>Can anyone suggest steps [if possible]
>Thanks
>Arnie
I do not understand what you mean by "control". All of the RF motion sensors
are one-way only. When they sense motion, they send an RF code to the
transceiver which then sends a PLC code on the powerline. There is no path
for sending messages to the motion sensors nor do the motion sensors have
any circuitry for receiving messages. The motion sensors are "programmed"
using their pushbuttons. All the Powerlinc controller can do is react to the
PLC codes on the powerline.
Similar ThreadsPosted
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:03 am
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:14 am
control motion/occupancy sensor using PowerLinc controller usb [2414U] July 19, 2007, 2:38 am
Control occupancy sensor/motion sensor using PLC July 19, 2007, 1:16 am
control motion/occupancy sensor using PLC[2414U] July 19, 2007, 4:22 am
Control motion/occupancy sensor using PLC [2414U] July 19, 2007, 5:48 am
X10 Wall Outlet Motion/Occupancy Sensor November 19, 2005, 10:05 am
PowerLinc Controller and X-10 switches December 8, 2005, 6:58 pm
Smarthome Powerlinc Controller February 14, 2006, 10:54 am
FS: INSTEON PowerLinc V2 Controller USB 2414U May 24, 2008, 2:01 am
powerlinc usb control api November 1, 2005, 2:47 pm
sensor controller October 8, 2006, 12:08 pm
control motion/occuupancy sensor using PLC [2414U] July 19, 2007, 3:25 am
Occupancy detection August 2, 2007, 11:28 pm
Powerlinc USB 32k February 15, 2006, 4:15 pm
