General Home Automation Re: CFL's and X-10
Subject Author Date
Re: CFL's and X-10 Ian Shef 06-23-08
Posted by Tom Stiller on June 28, 2008, 6:36 pm
> Did you expect to get an accurate, fact-based assessment out of that
> character?
did he say something that was factually incorrect?
Tom Stiller
PGP fingerprint = 5108 DDB2 9761 EDE5 E7E3 7BDA 71ED 6496 99C0 C7CF
Posted by Robert L Bass on June 28, 2008, 9:17 pm
Did he ever say anything that was factual?
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
Posted by Tom Stiller on June 28, 2008, 9:46 pm
From <http://www.epa.gov/mercury/spills/index.htm>
Before Clean-up: Air Out the Room
€        Have people and pets leave the room, and don't let anyone walk
through the breakage area on their way out.
€        Open a window and leave the room for 15 minutes or more.
€        Shut off the central forced-air heating/air conditioning system, if
you have one.
Clean-Up Steps for Hard Surfaces
€        Carefully scoop up glass pieces and powder using stiff paper or
cardboard and place them in a glass jar with metal lid (such as a
canning jar) or in a sealed plastic bag.
€        Use sticky tape, such as duct tape, to pick up any remaining small
glass fragments and powder.
€        Wipe the area clean with damp paper towels or disposable wet wipes.
Place towels in the glass jar or plastic bag.
€        Do not use a vacuum or broom to clean up the broken bulb on hard
surfaces.
Clean-up Steps for Carpeting or Rug
€        Carefully pick up glass fragments and place them in a glass jar
with metal lid (such as a canning jar) or in a sealed plastic bag.
€        If vacuuming is needed after all visible materials are removed,
vacuum the area where the bulb was broken.
€        Remove the vacuum bag (or empty and wipe the canister), and put the
bag or vacuum debris in a sealed plastic bag.
And more.
Sometimes even people you don't like are right.
Tom Stiller
Posted by Robert L Bass on June 29, 2008, 3:00 am
That's for serious mercury spills. It has no more to do with using CFLs in
your home than using a thermometer.
> --- snip ---
Yes, but what you quoted does nothing to make Poe honest or reliable. He's in
lock step with the Idiot. Don't trust anything he says and, more importantly,
beware of everything he does.
Regards,
Robert L Bass
Fax 941-870-3252
Posted by B Fuhrmann on June 29, 2008, 9:42 am
> in your home than using a thermometer.
No, that IS the official policy for CFLs.
It is basically the same as for thermometers.
It is not that difficult.
My complaints on CFLs are:
SLOW STARTUP
Really a problem for areas that I am in for a short period of time.
A pain in the butt for rooms that I will be in for longer periods but have
to endure low light for a significant time.
LACK OF DIMMABILITY
There are rooms where I want different levels of light depending on the
activity.
Bill Fuhrmann
Similar ThreadsPosted
Re: CFL's and X-10 June 15, 2008, 7:21 am
Re: CFL's and X-10 June 23, 2008, 3:00 pm
N:Vision CFL's March 24, 2007, 5:42 am
CFL's & Electronic Ballast bad??? January 2, 2008, 1:02 pm
