General Home Automation Question of the day
Subject Author Date
Question of the day ABLE_1 09-28-06
Posted by ABLE_1 on September 28, 2006, 11:12 pm
Hello All,
If you should be so happy to have a house that has more than one electrical
panel. (ie sub-panels) Can you get away with one signal bridge at the main
panel or is it wise to have one on each panel???
Also should you have two 200 amp panels (400amp service) as mains is it
suggested to have a signal bridge in each or will one do the job???
Thanks in advance.
Les
Posted by Jeff Volp on September 29, 2006, 9:28 am
> Hello All,
electrical
main
It depends on how loads are distributed.
We have two panels, but one panel just carries major loads like the A/C
compressors, stove, & dryer. Most branch circuits come into the other
panel, and one signal bridge would normally be installed there. However, we
don't even need one because all X10 circuits are wired into the same phase.
Even if your X10 loads are distributed across both panels, you may still be
able to get away with one signal bridge if the run between the two panels is
not too long. If your two panels are at opposite ends of a large house, and
equally share X10 loads, then you probably should install bridges at each
one.
Jeff
Posted by ABLE_1 on October 8, 2006, 11:30 pm
Thanks for the info Jeff. That is what I expected but just wanted to
confirm.
Les
> we
> phase.
> be
> is
> and
> one.
> Jeff
Similar ThreadsPosted
question October 24, 2005, 11:59 am
HI Im New and have a question April 25, 2006, 3:00 pm
Question of the day September 28, 2006, 11:12 pm
X10 Camera question February 9, 2005, 4:58 pm
Relays Question February 17, 2005, 4:56 am
X10 Control Question March 29, 2005, 8:36 am
HomeSeer Question March 30, 2005, 12:20 am
Question about this product June 9, 2005, 9:44 pm
General X10 question August 29, 2005, 5:27 pm
Illiterate X-10 Question October 25, 2005, 6:39 pm
Insteon question November 20, 2005, 12:32 pm
Keypadlinc question?? December 8, 2005, 1:55 pm
translator question January 20, 2006, 10:59 am
X10 General Question January 26, 2006, 1:49 pm
DS7000 question February 14, 2006, 8:39 am
