General Home Automation Plug-In X-10 Filter Recommendation?
Subject Author Date
Plug-In X-10 Filter Recommendation? David White 03-10-09
Posted by David White on March 10, 2009, 10:05 pm
I have discovered that my recently purchased LCD TV, when turned-on,
interferes with X-10 control of a light on the same circuit. If the TV
is off, X-10 works. If on, X-10 does not.
So I am thinking about using a plug-in filter. If I understand their
use, I would want to plug the TV into the filter and then the filter
into the wall. Is this correct?
Right now, the TV plugs into a surge suppressor (along with a computer)
and then the surge suppressor into the wall. Is it better to put the
filter between the suppressor and the wall or between the tv and the
suppressor? I'd think that the latter configuration would require a
filter rated for fewer amps than the former configuration. The tv specs
say that it uses 130 watts when on and less than 1 watt in standby (off).
Checking online (smarthome, ebay) I see 5 amp, 10 amp, and 15 amp
plug-in filter units. I see at least Leviton, FilterLinc, ACT, and X10
Pro brands of plug-in filters. Any recommendations on what size and
brand to use?
Thanks
Posted by Jeff Volp on March 10, 2009, 11:56 pm
The inexpensive XPPF from X10 should do the job. While rated 5A (600
watts), it does get warm when pushed that hard. You can put it between the
wall socket and surge suppressor unless your computer a lot of power. In
that case, you could filter just the offending LCD TV.
Jeff
>interferes with X-10 control of a light on the same circuit. If the TV is
> So I am thinking about using a plug-in filter. If I understand their use,
> I would want to plug the TV into the filter and then the filter into the
> suppressor? I'd think that the latter configuration would require a filter
> rated for fewer amps than the former configuration. The tv specs say that
> Checking online (smarthome, ebay) I see 5 amp, 10 amp, and 15 amp plug-in
> filter units. I see at least Leviton, FilterLinc, ACT, and X10 Pro brands
> of plug-in filters. Any recommendations on what size and brand to use?
> Thanks
Posted by David White on March 11, 2009, 12:35 am
Thanks Jeff. I just snagged one off Ebay.
> Jeff
>> Thanks
Posted by David White on March 16, 2009, 6:58 pm
Got one. It arrived. Plugged in and problem solved! Thanks again Jeff.
> Jeff
>> Thanks
Similar ThreadsPosted
Plug-In X-10 Filter Recommendation? March 10, 2009, 10:05 pm
Error (Subsystem: NS, #28) in PlugIn for LonMaker September 14, 2006, 6:32 am
X10 filter August 4, 2005, 5:24 pm
DIY X-10 (or Insteon) filter December 22, 2005, 7:22 am
Recommendation for distributed IO February 9, 2007, 7:40 pm
two prong x10 plug-in filter? February 7, 2005, 9:36 pm
X10 filter, 100A 230V. October 22, 2006, 5:09 am
X10 camera IR filter removal? December 26, 2006, 2:03 pm
Channel Vision whole house DSL filter March 28, 2007, 10:25 pm
OTA television channel deletion filter December 21, 2008, 1:44 am
Timer recommendation for porch lights August 20, 2005, 7:59 pm
X10 wireless motion sensor recommendation October 13, 2007, 12:33 am
X10: FD10 phase coupler/filter chematics September 7, 2008, 1:38 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
