General Home Automation Open garden gate indicator
Subject Author Date
Open garden gate indicator JD 07-14-07
Posted by JD on July 14, 2007, 8:31 am
I am looking for something that will let me know if one of my garden gates
is open or closed. I saw something in the Home Automation catalog but the
magnetic switch doesn't look like it is waterproof. I have also been
thinking about modifying a Craftsman Garage door open/closed system that I
use but am not quite sure how to do that.
Any ideas out there?
Thanks
JD
Posted by Robert L Bass on July 14, 2007, 10:53 am
> if one of my garden gates is open or closed. I
> but the magnetic switch doesn't look like it is
> waterproof. I have also been thinking about
> system that I use but am not quite sure how to
> do that. Any ideas out there?
Virtually all of the magnetic sensors (called "contacts")
used in the alarm industry are waterproof. GE Security,
GRI and Honeywell all make reliable, wide-gap contacts
that could easily be used for this purpose. Your choice
will depend on the distance between the gate and the
fence when it is closed. If it's tight fitting (less than 1/2
an inch) almost any standard door sensor will do. If the
gap is larger, up to 3", you'll need one of the models
used for a garage door. Standard door contacts cost
between $2 and $4 and wide gap; ones for a garage
door cost about $11 or so up to $27, depending on the
model.
If the gate is made of iron, you'll need a wide-gap contact.
These are available with brackets designed for mounting
on the kind of pipe used to build fences. On a reasonably
close-fitting, wooden fence gate you could fit a recessed
contact which is concealed from view. If you only need
one or two of the basic contacts, let me know and I'll send
you a sample. I sell hundreds of door contacts from
various manufacturers in my online store.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Posted by Nick Hull on July 16, 2007, 6:05 pm
> model.
I use magnetic reed switches on outdoor gates; they are
waterproof and work well BUT they can get welded by a near
lightning strike. Proper protection (zeners, diodes, chokes)
make them last longer. The high current ones take more abuse.
Similar ThreadsPosted
Open garden gate indicator July 14, 2007, 8:31 am
Open and Closr my Gate over the internet. July 3, 2008, 11:05 am
Preventing disease in your garden May 24, 2006, 2:06 pm
Garden hose automation - suggestions? August 16, 2005, 3:16 pm
gate switch December 10, 2005, 10:59 pm
Stanley Garge Door Status Indicator October 9, 2006, 4:35 pm
Computer Aided Gate Opener August 22, 2006, 1:16 pm
Open Source February 5, 2008, 5:25 pm
air conditioner open windows! February 24, 2005, 7:48 pm
ChannelPlus/Open House in OnQ Panel? June 29, 2005, 4:39 pm
Open Source Thermostat and more (Schematics) February 21, 2006, 2:08 am
KNXLive! an open soirce alternative to ETS September 14, 2006, 7:38 am
OpenRemote Debuts First Open Database for Home Automation (Centre Daily Times) October 2, 2008, 3:10 am
