Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by geo on April 12, 2005, 2:31 pm
Please log in for more thread options I'm a newcomer to X10 (although I used to play around with Radio Shack Plug-N-Power units many years ago, which I understand are the same thing). I recently Bought a kit consisting of the HR12A Palmpad, TM751 Transceiver and the LM465 lamp module. Now for my problem. I plugged a lamp into the TM751, and it worked fine. But at the other end of the same room, (next to our TV) I plugged another lamp into the LM465, and it started blinking once every second or so. I had an old Radio Shack appliance module laying around - and did the same thing. Both units respond to an "on" command. But when you turn them off, they revert to the blinking behavior. I suspect the problem may be linked to our Dish Network satellite dish. The box on top of the TV is connected via a phone line to a box that's plugged into an AC outlet. At the other end of the room, a similar box, also plugged into an AC outlet, is connected to the phone line. I'm guessing that the Dish Network set-top box uses something like X10 signals to talk to the box that's connected to our phone line. Is there some kind of filter I can use to keep the two separate? | ||||||||||||||||
Posted by Jack Ak on April 12, 2005, 10:55 pm
Please log in for more thread options Before looking for a filter, verify the spurious activity comes from the phone line boxes. Unplug both boxes and see if the problem disappears. Those boxes use the powerline to send signals between the boxes, so it is possible your X10 devices may be affected. The only solution to the problem may be running a separate phone line to the satellite receiver and eliminate use of the phone line extenders. One way to troubleshoot X10 problems is to unplug devices which are suspected of causing interference. | ||||||||||||||||
Posted by Thierry Parent on April 13, 2005, 12:37 am
I don't believe that it is related to the satellite dish system (this kind of transmission is modulated on a dedicate carrier frequency which should not interfere with basic zero crossing X10 protocol). It seems to be more in relation with "local control strange behaviour". did you tried different kind of lamp (filament bulb, halogen, low voltage halogen, fluorescen bulb) ? If filament bulb fixes the problem, you can apply "disabling local control" procedure explained on the www.geocities.com/idobartana site to solve it. Hope it help Thierry : > I'm a newcomer to X10 (although I used to play around with Radio Shack
> Plug-N-Power units many years ago, which I understand are the same > thing). I recently Bought a kit consisting of the HR12A Palmpad, TM751 > Transceiver and the LM465 lamp module. Now for my problem. > > I plugged a lamp into the TM751, and it worked fine. But at the other > end of the same room, (next to our TV) I plugged another lamp into the > LM465, and it started blinking once every second or so. I had an old > Radio Shack appliance module laying around - and did the same thing. > Both units respond to an "on" command. But when you turn them off, > they revert to the blinking behavior. > > I suspect the problem may be linked to our Dish Network satellite dish. > The box on top of the TV is connected via a phone line to a box that's > plugged into an AC outlet. At the other end of the room, a similar > box, also plugged into an AC outlet, is connected to the phone line. > I'm guessing that the Dish Network set-top box uses something like X10 > signals to talk to the box that's connected to our phone line. > > Is there some kind of filter I can use to keep the two separate? > | ||||||||||||||||
Posted by geo on April 13, 2005, 12:38 pm
Thierry Parent asked: > Did you tried different kind of lamp (filament bulb, halogen, low
voltage
Last night I opened up the lamp, which I thought had an ordinary incandescent bulb in it. Lo-and-behold, there was a flourescent, (the kind with a twisted tube that fits in an ordinary light socket). Replaced it with an ordinary 100W bulb, and problem solved. Thanks Thierry! | ||||||||||||||||
| Similar Threads | Posted |
| Modules switch on every second | April 12, 2005, 2:31 pm |
| Shallow x10 modules... | September 24, 2008, 11:33 pm |
| X10 (new modules) and Z-Wave from Norway | February 18, 2005, 5:40 pm |
| Anyone know of any X-10 closeouts on appliance modules, etc? | August 2, 2005, 7:18 am |
| X10 dimmer modules and CF lamps | August 12, 2006, 8:29 pm |
| Do X10 modules degrade over time? | September 10, 2006, 8:37 pm |
| 8 X-10 Universal modules for sale | November 4, 2006, 3:47 pm |
| CF light bulbs and X10 modules | July 23, 2007, 12:58 am |
| I sell my X10 DIN modules... anyone interested? (Spain) | September 28, 2007, 5:45 am |
| ICON switches and modules are back | February 19, 2008, 7:33 am |
| Local Sense on Z-Wave plug in modules? | February 9, 2007, 1:45 am |
| Intermittent operation of 3 appliance modules AM486 | January 3, 2008, 5:47 pm |
| [Q] Can I use 230V/50Hz X10 Modules to 220V/60Hz country? | January 20, 2006, 2:04 am |
| What switch is this | August 13, 2008, 9:29 am |
| In Wall Switch | August 26, 2005, 5:52 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
