General Home Automation MR16 LEDs for Landscape Lights
Subject Author Date
MR16 LEDs for Landscape Lights Jeff Volp 06-22-08
Posted by Jeff Volp on July 1, 2008, 12:02 am
The final LED MR16 sample for the landscape lighting arrived. This is the
2.6W warm-white unit with 9 surface-mount LEDs that was linked at the very
beginning of this thread. It outputs a smooth wide-angle beam, which is
perfect for these lights. However, like the 48-LED unit, it doesn’t do a
good job bringing out the warm red tones in the crushed rock. It is also
not quite a bright as the 20W halogen. But for an energy savings of 87%, it
does a very impressive job.
Jeff
Posted by Robert L Bass on July 1, 2008, 3:37 am
Jeff,
I've been looking at various colored LEDs for use on my motorcycle. There now
are extremely bright LEDs available in a multitude of colors. Most of the
"white" LEDs I've seen are actually a pale shade of blue. If you want to
bring out the warm tones in the brick, try adding a supplemental string of
rose or even red colored LEDs. If you use red, select a lower power. You
don't need much. A few manufacturers offer strings with adjustable brightness
and even variegated colors. The options are surely going to increase with
time.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
Posted by Jeff Volp on July 1, 2008, 10:24 am
That is a good suggestion, but not really feasible for this application.
These are standard 12VAC landscape lights that accept a single MR16 bulb. I
did choose the "Warm White" versions (3000-3500K). While the light looks
good indoors, it must have a narrow spectrum. The red crushed rock looks a
grayish yellow. However, the rock wall itself does have its natural color.
For sheer brightness, I have been very impressed by the CREE units.
Jeff
> now are extremely bright LEDs available in a multitude of colors. Most of
> the "white" LEDs I've seen are actually a pale shade of blue. If you want
> to bring out the warm tones in the brick, try adding a supplemental string
> of rose or even red colored LEDs. If you use red, select a lower power.
> You don't need much. A few manufacturers offer strings with adjustable
> brightness and even variegated colors. The options are surely going to
> increase with time.
Posted by B Fuhrmann on July 1, 2008, 6:41 pm
"Jeff Volp" wrote ...
> I did choose the "Warm White" versions (3000-3500K). While the light
> looks good indoors, it must have a narrow spectrum. The red crushed rock
> looks a grayish yellow. However, the rock wall itself does have its
> natural color.
By nature LEDs are narrow spectrum devices. There are a few tricks used to
create the wider white band but it isn't all that good.
Wikipedia's LED article discusses some of them.
http://en.wikipedia.org/wiki/LED
Here are some spectra that a person took from several different white LEDs
Bill Fuhrmann
Posted by Robert L Bass on July 1, 2008, 9:22 pm
If they're not too hot (they shouldn't be), you might consider placing a glass
filter over them. Gels work fine indoors but they fall apart after a rain.
Regards,
Robert L Bass
Fax 941-870-3252
Similar ThreadsPosted
MR16 LEDs for Landscape Lights June 22, 2008, 11:27 pm
Halogen Bulbs mr16 November 19, 2005, 7:14 pm
Halogen Bulbs mr16 November 19, 2005, 7:17 pm
Automated lawnmower using rate gyro, RS485 and Infrared leds December 25, 2007, 1:38 pm
Landscape Lighting Controller November 8, 2005, 5:09 pm
LED's for landscape (cont) July 7, 2008, 12:07 pm
X10 and LED lights December 4, 2005, 4:48 pm
Lights flickering August 30, 2005, 5:41 pm
Keeping lights off at night March 3, 2005, 11:49 pm
LED Lights and other automation protocols April 5, 2005, 8:13 pm
Re: X10 with Compact Fluorescent Lights (fwd) July 13, 2005, 12:10 am
caution is needed with lights! December 8, 2005, 2:02 pm
dimmer lights for house February 12, 2006, 7:10 am
Controling Holiday Lights October 15, 2006, 9:37 pm
Random X10 all lights on/all units off over and over December 9, 2006, 12:05 am
