General Home Automation Is xPL the ideal work-around? Need to access the LPT port from MisterHouse...
Subject Author Date
Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... Jack Edin 10-21-05
Posted by Jack Edin on October 21, 2005, 12:50 pm
Greetings.
I need to send a byte out the LPT port. Sounds simple enough...
Then I searched and discovered Mister House is limited by Perl, which
can't access the LPT port.
Dohh!
Bruce told me at one time that I should seek to use the xPL or xAP
interfaces. Mister House can easily interface with them both.
So I hope xPL isn't limited, and that it CAN access the LPT port.
My application is super-simple. Somebody who knows what they're doing
should be able to write something is a few minutes.
Anybody have any insite?
Thankx, in advance.
Jack
Posted by Frank Mc Alinden on October 22, 2005, 6:54 am
Hi Jack
Best to ask the question over at the xPL list
http://groups.yahoo.com/group/ukha_xpl/
I use xPL but im not aware of any LPT Plugin....
Frank
Frank Mc Alinden
Posted by Jack Edin on October 21, 2005, 2:22 pm
Thanks Frank,
I did just that.
I joined that group, and asked the question therein...
I hope somebody takes the time to help.
Sincerely,
Jack
Frank Mc Alinden wrote:
> Hi Jack
> Frank
Similar ThreadsPosted
Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... October 21, 2005, 12:50 pm
CM15A and MisterHouse Module Starting Point August 28, 2005, 4:47 pm
Supply 24 Port Patch Panels,24 Patch Panels,24 Port UTP Patch Panels,24 Port Cat5e Patch Panels,RJ45 Patch Panels,Modular Patch Panels April 1, 2006, 3:25 am
PC parallel port (LPT) and voltage September 21, 2008, 3:47 am
Greyfox F7759 8 port router September 20, 2005, 11:58 am
Need Programable IR remote driven by usb port June 12, 2007, 11:53 am
Record temperature to computer via serial port July 31, 2006, 2:05 pm
House Access Help July 29, 2006, 2:05 am
need basic program to print string to printer port August 7, 2005, 2:30 am
Jack PC "will change everything...COMPUTER ...FITS IN .. WALL PORT" June 15, 2006, 8:57 am
reading in data from rs232 port, require to resend as an email April 2, 2008, 7:20 am
the ElkM1 "RP access code": a sham? October 10, 2006, 5:34 pm
Re: PR: Access Control Systems at www.BassBurglarAlarms.com May 9, 2007, 7:42 am
Thermostat access temp info January 19, 2008, 7:05 pm
Simple access security setup for home October 15, 2005, 7:48 pm
