Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by JT on May 15, 2006, 7:49 am
Please log in for more thread options Thanks, JT | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by BruceR on May 15, 2006, 7:57 am
Please log in for more thread options the midst of converting almost all of my X10 stuff to Insteon. The setup is a bit tricky and unless they develop a SIMPLE software interface for it I think it will be their downfall as the average consumer won't bother dealing with it. (How I long for the easy days of code wheels!) I've done so much switch tapping this weekend I feel like a woodpecker! That being said, I don't know if Zwave or the others are any easier. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Robert L Bass on May 15, 2006, 11:55 am
Please log in for more thread options > That being said, I don't know if Zwave or
> the others are any easier. Bruce, I'll be able to answer that fairly soon. I'm installing an ELK-M1G in our new home and I plan to use Z-Wave extensively. At present I'm researching communicating (hard-wired) swimming pool controllers since the unit on the wall is shot. -- Regards, Robert L Bass =============================>
Bass Home Electronics
4883 Fallcrest Circle Sarasota · Florida · 34233 941-866-1100 Sales & Tech Support http://www.bassburglaralarms.com =============================>
Posted by Dave Houston on May 15, 2006, 9:44 pm
Please log in for more thread options http://www.smarthome.com/2416.html
>I can't compare for you because I've not tried Zwave. However, I am in
>the midst of converting almost all of my X10 stuff to Insteon. The >setup is a bit tricky and unless they develop a SIMPLE software >interface for it I think it will be their downfall as the average >consumer won't bother dealing with it. (How I long for the easy days of >code wheels!) I've done so much switch tapping this weekend I feel like >a woodpecker! That being said, I don't know if Zwave or the others are >any easier. > > >> I can't decide between the 2. Any experiences on either of them?
>> >> Thanks, >> JT >
Posted by BruceR on May 15, 2006, 10:06 pm
Please log in for more thread options Thanks for the heads up on that, I think it may be worth a try. I've
been playing with PowerHome but until I get my arms around it, the tap-tap method is still my SOP. BTW, re: quality issues. So far I've found 2 defects among the 27 Insteon devices I've installed to date. One is a bad V2 Wall Dimmer that won't remember it's ramp rate or dim settings and the other is a bad Keypad Linc that won't control anything other than it's native load. > http://www.smarthome.com/2416.html
>> in the midst of converting almost all of my X10 stuff to Insteon. >> The setup is a bit tricky and unless they develop a SIMPLE software >> interface for it I think it will be their downfall as the average >> consumer won't bother dealing with it. (How I long for the easy days >> of code wheels!) I've done so much switch tapping this weekend I >> feel like a woodpecker! That being said, I don't know if Zwave or >> the others are any easier. >> >> >>> I can't decide between the 2. Any experiences on either of them?
>>> >>> Thanks, >>> JT | ||||||||||||||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Insteon vs UPB vs Zwave | February 18, 2006, 10:32 pm |
| Insteon or Zwave? | May 15, 2006, 7:49 am |
| Software for Insteon and Zwave | May 25, 2007, 3:30 am |
| Elk and Zwave | March 18, 2007, 12:40 pm |
| Looking at Zwave products and need recommendations? | August 28, 2005, 8:10 pm |
| Harmony Remote supports Zwave | September 7, 2005, 2:35 pm |
| Zwave Prices going up & Free Home Automation Auction | March 4, 2005, 1:31 pm |
| Zwave In-Wall Switch/Dimmer with RF Remote Control Capabilities | January 7, 2007, 9:42 pm |
| INSTEON dimmers can respond to both X-10 and INSTEON commands | July 29, 2005, 7:51 am |
| Insteon? | March 11, 2005, 12:27 am |
| Insteon? | March 12, 2005, 10:32 pm |
| Insteon | April 16, 2005, 1:04 am |
| X10/Insteon | January 29, 2006, 5:04 pm |
| Insteon - WOW | March 26, 2006, 9:57 pm |
| X10 AGC and Insteon | October 23, 2006, 9:45 am |
Insteon or Zwave?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks,
> JT
