Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jim Thompson on October 25, 2005, 6:39 pm
Please log in for more thread options The number of different X-10 components out there is overwhelming to someone who has not used them before. What I want is very simple... When Circuit A is activated by a conventional switch I want Circuit B to be also activated. When Circuit A is deactivated by a conventional switch I want Circuit B to be also deactivated. Circuit B only has a source of power but no conventional switching of its own. Seems there should be small "do-hickeys" that I could simply wire into each junction box, but I'm having trouble zeroing-in on the right components. Thanks! ...Jim Thompson -- | James E.Thompson, P.E. | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona Voice:(480)460-2350 | | | E-mail Address at Website Fax:(480)460-2142 | Brass Rat | | http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food. | ||||||||||||||||||||||||||||
Posted by E. Lee Dickinson on October 25, 2005, 11:41 pm
Please log in for more thread options Jim -- James Lipsit has a bit about sensing current to trigger X10 devices on his website: http://james.lipsit.com/tvsensor.htm Also, have a look at the powerflash module: http://www.smarthome.com/4060.html and consider that, combined with http://www.smarthome.com/2250aw.html I would suggest a 120v relay parallel with your switched load, providing contact closure to the 4060, which will send an X10 "on" command to the 2250 E. Lee Dickinson Entertainment Design and Technology www.leedickinson.com | ||||||||||||||||||||||||||||
Posted by Jim Thompson on October 25, 2005, 8:45 pm
On Tue, 25 Oct 2005 23:41:40 -0400, "E. Lee Dickinson" >
>> someone who has not used them before. >> >> What I want is very simple... >> >> When Circuit A is activated by a conventional switch I want Circuit B >> to be also activated. >> >> When Circuit A is deactivated by a conventional switch I want Circuit >> B to be also deactivated. >> >> Circuit B only has a source of power but no conventional switching of >> its own. >> >> Seems there should be small "do-hickeys" that I could simply wire into >> each junction box, but I'm having trouble zeroing-in on the right >> components. >> >> Thanks! >> >> ...Jim Thompson >
>Jim -- > >James Lipsit has a bit about sensing current to trigger X10 devices on his >website: > >http://james.lipsit.com/tvsensor.htm > >Also, have a look at the powerflash module: >http://www.smarthome.com/4060.html and consider that, combined with >http://www.smarthome.com/2250aw.html > >I would suggest a 120v relay parallel with your switched load, providing >contact closure to the 4060, which will send an X10 "on" command to the 2250 > >E. Lee Dickinson >Entertainment Design and Technology >www.leedickinson.com > Thanks, Lee, I'll check it out. ...Jim Thompson -- | James E.Thompson, P.E. | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona Voice:(480)460-2350 | | | E-mail Address at Website Fax:(480)460-2142 | Brass Rat | | http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food. | ||||||||||||||||||||||||||||
Posted by BruceR on October 26, 2005, 2:30 am
Smarthome's wall switches send an X10 signal when manually operated. So, if you put the switch on Circuit A and turned it on or off manually, it would send an X10 signal like A1-On (or Off) which would control an X10 module set to that code to control Circuit B. From:Jim Thompson thegreatone@example.com > The number of different X-10 components out there is overwhelming to
> someone who has not used them before. > > What I want is very simple... > > When Circuit A is activated by a conventional switch I want Circuit B > to be also activated. > > When Circuit A is deactivated by a conventional switch I want Circuit > B to be also deactivated. > > Circuit B only has a source of power but no conventional switching of > its own. > > Seems there should be small "do-hickeys" that I could simply wire into > each junction box, but I'm having trouble zeroing-in on the right > components. > > Thanks! > > ...Jim Thompson > -- >> James E.Thompson, P.E. | mens |
>> Analog Innovations, Inc. | et | >> Analog/Mixed-Signal ASIC's and Discrete Systems | manus | >> Phoenix, Arizona Voice:(480)460-2350 | | >> E-mail Address at Website Fax:(480)460-2142 | Brass Rat | >> http://www.analog-innovations.com | 1962 | >
Posted by Jim Thompson on October 25, 2005, 7:39 pm
[snip]
>if you put the switch on Circuit A and turned it on or off manually, it >would send an X10 signal like A1-On (or Off) which would control an X10 >module set to that code to control Circuit B. > >>
>> Seems there should be small "do-hickeys" that I could simply wire into >> each junction box, but I'm having trouble zeroing-in on the right >> components. >> >> Thanks! >> >> ...Jim Thompson I was hoping there really was a set of "do-hickeys" The X-10 switch blocks don't really fit my application... outdoor-weather-protected switches. Alternatively, anyone have schematics of X-10 transmitters and receivers? ...Jim Thompson -- | James E.Thompson, P.E. | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona Voice:(480)460-2350 | | | E-mail Address at Website Fax:(480)460-2142 | Brass Rat | | http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food. | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Illiterate X-10 Question | October 25, 2005, 6:39 pm |
| question | October 24, 2005, 11:59 am |
| HI Im New and have a question | April 25, 2006, 3:00 pm |
| Question of the day | September 28, 2006, 11:12 pm |
| X10 Camera question | February 9, 2005, 4:58 pm |
| Relays Question | February 17, 2005, 4:56 am |
| X10 Control Question | March 29, 2005, 8:36 am |
| HomeSeer Question | March 30, 2005, 12:20 am |
| Question about this product | June 9, 2005, 9:44 pm |
| General X10 question | August 29, 2005, 5:27 pm |
| Insteon question | November 20, 2005, 12:32 pm |
| Keypadlinc question?? | December 8, 2005, 1:55 pm |
| translator question | January 20, 2006, 10:59 am |
| X10 General Question | January 26, 2006, 1:49 pm |
| DS7000 question | February 14, 2006, 8:39 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> its own.
> components.
> Thanks!
> ...Jim Thompson
