Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Git on March 21, 2007, 10:51 am
Please log in for more thread options cable runs back to a comms room, i also have speakers wired into the speakers, each speaker cable also goes back to the comms room. What i have: I would like to have a PC in the COMMS room and have some kind of touch screens in some rooms to access music files on the PC in the comms room and play them in specific rooms through the ceiling speakers. I would also like to access my PC through my Sony Bravia KDL-40S2030U. this also has a CAT5 cable near it. my question is what do i need to do this, and where do i get it? Thanks Gary | |||||||||||||||||||
Posted by Slammer on March 21, 2007, 1:18 pm
Please log in for more thread options You can contact someone who sell Celestron. I hope you have deep pockets. Promixis has a neat package in its NetRemote Software if you're a DYI. The problem of accessing your PC from your TV is interfacing to the PC network, your TV is not a terminal. I have used NetRemote and it works well once you get the wireless network setup. The software configuration wasn't bad and the touch screen PDAs for remotes are nice. Michael | |||||||||||||||||||
Posted by Robert L Bass on March 21, 2007, 5:25 pm
Please log in for more thread options > Hi, I have wired my house with CAT5 cabling into each room, each CAT5
> cable runs back to a comms room, i also have speakers wired into the > speakers, each speaker cable also goes back to the comms room. > > What i have: I would like to have a PC in the COMMS room and have some > kind of touch screens in some rooms to access music files on the PC in > the comms room and play them in specific rooms through the ceiling > speakers. I would also like to access my PC through my Sony Bravia > KDL-40S2030U. this also has a CAT5 cable near it. > > my question is what do i need to do this, and where do i get it? Russound makes a 6-source, 6-zone (room) system that uses the kind of cabling you've installed. Each room gets a CAT5 cable back to the source room. Each room also gets a pair of speaker cables back to the source room. Connect a keypad / display unit to the CAT5 in each room to select a source, operate it and select the volume for that room. The system is expandable in two ways. You can go to six zones plus four "slave" rooms which play the same source as their respective master rooms with independent volume controls. Typical use for this type of expansion is a master bedroom with a bathroom or a kitchen and dining room. Alternatively, the system can be expanded by cascading another controller. This would give you up to 12 master and 8 slave zones. The system is called a Russound CAV66. There are several keypad options, including a UNO-TS2 which is a touchscreen and the UNO-S2 which is a conventional keypad. Keypads cost less than touchscreens. Touchscreens can display playlist, channel name, artist name, and song title if the system is coupled with a Russound tuner or media server. The CAV series does both audio and video distribution. There's also a CAA66 system which is audio only. There are other brands with similar features but I'm a bit biased in favor of Russound because I sell them. :^) -- Regards, Robert L Bass =============================>
Bass Home Electronics
941-925-8650 4883 Fallcrest Circle Sarasota · Florida · 34233 http://www.bassburglaralarms.com =============================>
Posted by Git on April 2, 2007, 10:02 am
> > cable runs back to a comms room, i also have speakers wired into the > > speakers, each speaker cable also goes back to the comms room. >
> > kind of touch screens in some rooms to access music files on the PC in > > the comms room and play them in specific rooms through the ceiling > > speakers. I would also like to access my PC through my Sony Bravia > > KDL-40S2030U. this also has a CAT5 cable near it. >
> Russound makes a 6-source, 6-zone (room) system that uses the kind of cab= > the source room. Each room also gets a pair of speaker cables back to th=
> in each room to select a source, operate it and select the volume for tha=
t room.
> The system is expandable in two ways. You can go to six zones plus four = > respective master rooms with independent volume controls. Typical use fo=
> > Alternatively, the system can be expanded by cascading another controller= > The system is called a Russound CAV66. There are several keypad options,=
> which is a conventional keypad. Keypads cost less than touchscreens. To=
> and song title if the system is coupled with a Russound tuner or media se=
> > There are other brands with similar features but I'm a bit biased in favo= >
> -- > > Regards, > Robert L Bass > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D> > Bass Home Electronics > 941-925-8650 > 4883 Fallcrest Circle > Sarasota =B7 Florida =B7 34233http://www.bassburglaralarms.com > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D> Thanks for the advice guys! I have a better idea on where to go now! Cheers! Gary | |||||||||||||||||||
| Similar Threads | Posted |
| Home audio | March 21, 2007, 10:51 am |
| Home Audio Automation | October 11, 2005, 12:20 pm |
| Running Audio Over Home Network | April 23, 2006, 4:48 pm |
| Help: home audio distribution scheme | April 30, 2006, 12:16 am |
| Home Audio and Windows Vista | March 8, 2007, 3:42 pm |
| Use of Audio Matrix Mixers in Home Automation | September 25, 2005, 10:29 pm |
| Connect home audio receiver to computer | November 28, 2005, 6:57 pm |
| PR: Draper Home Theater and Home Automation Products @ Bass Home Electronics | December 9, 2006, 12:59 am |
| Public posting home automation/home entertainment weblog | February 13, 2005, 9:40 pm |
| PR: Home Automation Power Supplies available at Bass Home Electronics | October 22, 2006, 8:33 am |
| Powerline Audio | April 14, 2005, 3:39 am |
| Audio over Cat5 ??? | April 17, 2005, 9:43 pm |
| Audio over Cat5 ??? | April 18, 2005, 5:27 am |
| Whole-House Audio | September 17, 2005, 11:04 am |
| Home Automation in a Alternate Home Power Environment | June 15, 2005, 3:02 pm |
Home audio
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks
> Gary
