General Home Automation HA Primer - Pos and cons of X-10, Z-wave, Insteon, UPB
Subject Author Date
HA Primer - Pos and cons of X-10, Z-wave, Insteon, UPB echo 04-23-07
Posted by echo on April 23, 2007, 2:06 am
So I already have a house chock full of X-10, but as usual reliability is
still somewhat of an issue and commands still get lost in the ether. It
would be nice to add a level of "robustness" to the system. So I start this
thread and hope it can become a quick primer on the newer tech versus the
X-10 or a mini buyers guide.
So what if any would be a good technology to invest in for your modern house
? What are the simple pros and cons of Z-wave and Insteon versus X-10 for a
24/7 PC based automation system. Are there any new technologies promising to
make obsolete all the others ?
I'll open by summarizing X-10s pros and cons for newbies who might stumble
upon this and leave the Zigbee Insteon, etc for other to chime in about.
An X-10 "controller" sends a signal to a "module". Modules can turn on,
off or dim lights etc. The X-10 controllers and modules constitute a
primitive network.
X-10 Build quality
X-10 is the company who created the first home automation products for the
consumer. The technology was fairly advanced for its day, but that was back
in the seventies and has seen little improvement since then. X-10 has
developed new models over the years but they have lacked the polish of a
product suitable for modern homes. Indeed the company seems more interested
in quantity of sales versus quality. The plastics they chose degraded and
discolored readily, circuit boards suffered from cold solder joints, wall
switch contacts were fragile. There are newer models but the best ones
always seem to be made by companies other than X-10. Any serious old-school
X-10 home automator likely has a box of dead X-10 parts waiting to be
recycled when the next module dies. Home Automation got off to a rocky start
since X-10 was doomed to be a hobby for the technically inclined. Poor
build quality was X-10s first real problem.
X-10 and powerline noise
X-10's underlying technology is part of its second problem. The homes
powerlines that the modules are wired or plugged into, are used to
distribute the signals. The signal is one way and modules have no provision
to send an acknowledgment. More on that later. If you had an operating TV
or motorized appliance plugged into the same circuit as a module, it was
unlikely the module would work due to noise on the powerlines.
X-10 phase coupling
Houses in North America use split phase wiring (2 x 110volt phases = 220V).
The X-10 signal had to be able to jump across the from one phase to the
other or the signal would only reach half the outlets in the house. A
capacitive signal bridge of the phases using a module called a "phase
coupler" helped for the most part but required wiring into a 220volt circuit
either in a breaker box or a dryer or stove outlet. This was not for the
average home owner and is the third problem.
X-10 device limitations
There are 16 House codes x 16 Unit codes = 256 useable addresses. It was
thought that no one would use more than 16 units in their houses. Signals
travel on the powerline up to the power pole, cross over to the other phase
and back down. In many cases a neighbor who used X-10 could control your
lights if they share the same power pole. So the idea was to allow each
house to use 16 modules and there could be 16 houses. Who'd have thought I
could have 16 devices in a bedroom alone. So this is surely a limitation and
X-10s fourth problem.
X-10 network speed
Commands can only be sent at the zero crossing of the AC waveform which
severely limits the amount of information that can be passed in a reasonable
amount of time. X-10 control systems have visible lag due to the speed
limitations. The fifth problem has and can not be solved with current X-10
technology.
X-10 one-way network
A big hurdle for automators was not knowing if the signal reached the module
or not. X-10s answer was the "2-way module". They are not really 2-way
since they can't acknowledge a command directly but they can be polled. the
problem is that due to the slow speed of the X-10 network the polling
responses can collide with other commands being sent. X-10 2-way is not
worth the extra money or trouble. This sixth problem is also hard wired into
the protocol.
X-10 user unfriendly
I had a friend insist on dimming his stereo with an X-10 lamp module, only
to watch his amp go up in smoke taking the module with it. Okay these are
electrical loads, and the problem is not unique to X-10, all electrical
dimmers behave in a similar fashion. A consumer having to know what an
inductive load is a mind bender for most, if not all, non technical people.
The seventh problem for X-10.
Those are the 7 deadly sins in HA as I see it. Yes there may be more but
lets get on to the good stuff. X-10 has a wide product line and the
availability of unique modules not yet available with other network
protocols. An example of this might be the PR511 floodlight motion detector.
Pricing can also be a factor and X-10 seems to give stuff away killing the
smaller dedicated home automation dealers.
Please confine the comments to other technologies since X-10 has already
been covered.
Posted by Jeff Volp on April 23, 2007, 10:25 am
Since I seem to be one of the few X10 supporters still here, I'll add a few
comments:
> this
> house
> a
> to
> primitive network.
> X-10 Build quality
> back
> interested
> old-school
> start
Modules made by X10 are very inexpensive. Their build quality reflects that
fact. Higher quality X10 products are available from other manufactureres
at much higher prices.
> provision
Actually, "signal suckers" are more of an issue than noise sources. Most
X10 transmitters have limited power output, and their signals are easily
attenuated by devices that include a capacitor directly across the
powerline, such as most computers.
> X-10 phase coupling
> 220V).
> circuit
True, but there are plug-in versions now available that work for many
people.
> phase
> and
And 640K of RAM and a 20MB harddrive was all any computer user would ever
need.
There is a signal blocker that can be installed at the distribution panel
that allows you to keep all 256 codes for yourself. However, a few house
codes will probably serve the needs of most users.
> X-10 network speed
> reasonable
> technology.
True again. However, X10 speed is adaquate for most home automation
applications. Since our Oceltot controls virtually everthing here, the
delay is transparent to us. The delay usually becomes a factor if you use
X10 motion detectors to trigger lighting.
> module
> the
> into
> the protocol.
No answer back is necessary if there is communication reliablity. That is
addressed by providing adaquate signal levels at all modules. You almost
never ask for return receipt when you mail something. X10 can achieve the
same level of communication reliability.
> people.
That is an X10 problem? They do call it a LAMP module.
> detector.
Agree here.
> been covered.
Yes, see: http://jeffvolp.home.att.net/x10_info/x10_troubleshooting.htm
Jeff
Posted by Dan Lanciani on April 23, 2007, 3:43 pm
Actually, they can be configured to acknowledge a command (or any state
change). I've never needed this feature because (a) I don't have the
reliability problems you are worried about and (b) my use for 2-way
functionality is generally to see in what state some other person/process
has left the device--something that is usually best done at the moment I
want the information. You might want to take a look at X10's extended
command set; it is quite complete.
                                Dan Lanciani
                                ddl@danlan.*com
Posted by Dave Houston on April 23, 2007, 6:02 pm
And, most of the Smarthome designed X10-compatible modules report changes
and respond to Status Request with the current preset dim level, even
transmitting an OFF should a bulb burn out.
Posted by echo on April 25, 2007, 2:59 am
So lets all beat a dead horse. You can't make a silk purse out of a sows
ear. X-10 has had its day and it is time for a more robust technology to
fill the need and fix the issues I mentioned. Until we get more robust user
friendly devices out there HA will be for the geeks. I would never
recommend X-10 for a serious installation because of the 7 problems. Just
think how users respond to Windows vs DOS and how Google has changed our
lives. No way will home automation come of age until we abandon this old
crap. Using signal bridges and having to add filters to TVs and not using
power bars with filters that eat x-10. Need I go on. I used to sell this
stuff. There is nothing modern about X-10 and justifying its continued
sales is like hanging on to DOS. Oh ya..I like DOS and have one PC running
24/7 on DOS 6 oddly enough it runs an ECS based X-10 system. Very powerful
in its day, 10+ years ago.
As for two-way, sorry X-10 is not. The newer modules can respond because of
modern PICs and programming but the protocol underlying is the problem. In a
proper communication system the network protocol must handle the error
correction and acknowledgments not the application (module). Having a
module respond is a Band-Aid that does not work. It clutters up the
powerline with even more X-10 commands so that more collisions occur and
even more commands get lost making the system less reliable. Answerback
modules must be used carefully allowing a time for response. Again, not too
friendly.
The TCP/IP would be great if it could be implemented over powerlines. But
an even more robust protocol would be nice where any module plugged into the
homes power system could be auto-detected and have a property sheet
instantly available to the control software.
I have a feeling a hybrid system of some kind may be good since powerline
commands can't be heard by low voltage DC devices. These could easily use a
wireless protocol.
As I mentioned X-10 has been discussed. Lets talk about something new like
the way Insteon works or Zwave, Zigbee, or Home PNP
writes:
Similar ThreadsPosted
HA Primer - Pos and cons of X-10, Z-wave, Insteon, UPB April 23, 2007, 2:06 am
Insteon vs UPB vs Zwave February 18, 2006, 10:32 pm
Insteon or Zwave? May 15, 2006, 7:49 am
Software for Insteon and Zwave May 25, 2007, 3:30 am
Elk and Zwave March 18, 2007, 12:40 pm
Looking at Zwave products and need recommendations? August 28, 2005, 8:10 pm
Harmony Remote supports Zwave September 7, 2005, 2:35 pm
Zwave Prices going up & Free Home Automation Auction March 4, 2005, 1:31 pm
Zwave In-Wall Switch/Dimmer with RF Remote Control Capabilities January 7, 2007, 9:42 pm
INSTEON dimmers can respond to both X-10 and INSTEON commands July 29, 2005, 7:51 am
Insteon? March 11, 2005, 12:27 am
Insteon? March 12, 2005, 10:32 pm
Insteon April 16, 2005, 1:04 am
X10/Insteon January 29, 2006, 5:04 pm
Insteon - WOW March 26, 2006, 9:57 pm
