General Home Automation Garage door control
Subject Author Date
Garage door control Spud Demon 05-07-09
Posted by Spud Demon on May 7, 2009, 7:14 pm
I want to automate my garage door using Linux. The idea is that the
computer records which codes are pressed and triggers the door if one
is correct. It also takes a picture of the person at the control. So
I need recommendations for the following pieces of hardware:
* keypad -- to be used in the script, not as a console keypad. It
will be mounted outdoors so it shouldn't be too expensive. Preferably
USB.
* relay -- I found the Super4 http://emx.net.au/super4usbrelay.htm Is
it the best for the price?
* camera -- also mounted outdoors (but under an eve so it won't get
too wet)
* open/closed sensor
* USB extender -- the garage door is 75' away from the computer I want
to use, 30' away from one I could use in a pinch.-
Anything else I should know before I start?
Posted by Chris Davies on May 8, 2009, 3:49 am
> is correct.
You're prepared to forego the door opening if your server is
unavailable? You might want to take a look at using a hardware watchdog to
reset the system if it's failing to respond. Oh, and a UPS of some sort.
Chris
Posted by Markus Baertschi on May 8, 2009, 4:43 am
> > I want to automate my garage door using Linux. =A0The idea is that the
> > is correct.
> unavailable? You might want to take a look at using a hardware watchdog t=
o
> Chris
For the keypad/code/garage opening part I'd use an already available
door opening keypad. That makes you independent on your linux
computer to open the door. The door opening process triggers
linux to take a picture. So if the PC is down you don't have a picture
but can get in to fix it.
Markus
Posted by Spud Demon on May 8, 2009, 9:57 am
> > > is correct.
> > Chris
> Markus
I want to log all incorrect keypad attempts. Yes I do have normal
garage door remotes which can bypass the keypad, but I always take my
front door key with me in case of power failure anyway. Aside from
long-duration power outages, my systems have pretty high availability.
It seems like the keypad might be the limiting factor though. How
about a UHF remote, has anybody connected one of those to a Linux
system?
Posted by Phil W Lee on May 8, 2009, 10:17 am
06:57:46 -0700 (PDT) the perfect time to write:
>> > > is correct.
>> > Chris
>> Markus
>system?
Would one of the usb numeric keypads (sold for notebooks) fit the
bill?
Similar ThreadsPosted
Garage door control May 7, 2009, 7:14 pm
control outside lights with garage door remote? February 8, 2006, 2:40 pm
Control garage lights with door opener? October 26, 2007, 2:49 pm
Garage door remote control constantly transmitting?? February 10, 2006, 6:23 pm
Sears Garage door opener + control outdoor lights January 15, 2007, 10:24 pm
Automatic Garage Door July 15, 2006, 1:38 am
Automatic Garage Door July 15, 2006, 6:40 am
Automatic Garage Door July 15, 2006, 7:40 am
Automatic Garage Door July 16, 2006, 8:43 am
One more Garage Door / X10 Question February 26, 2007, 4:53 pm
Reed Switch for Garage Door February 26, 2006, 11:40 am
Chamerlain Garage Door Monitor November 17, 2006, 10:08 am
Using wifi card to operate garage door June 25, 2005, 4:31 pm
Old garage door opener...need a new remote/receiver March 29, 2006, 12:55 pm
Garage door closes automatically after a preset time June 15, 2006, 2:05 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
