General Home Automation Does anyone know who is making these light bulbs?
Subject Author Date
Does anyone know who is making these light bulbs? Robert Green 03-23-07
Posted by Robert Green on March 23, 2007, 11:48 am
http://en.wikipedia.org/wiki/Compact_fluorescent_lamp#How_they_work
says:
"The Cold Cathode Fluorescent Light (CCFL) is one of the newest forms of
CFL. CCFLs use electrodes without a filament. The voltage of CCFL lamps is
about 5 times higher than CFL lamps and the current is about 10 times lower.
CCFL lamps have a diameter of about 3 millimeters. The lifetime of CCFL
lamps is about 50,000 hours. The lumens per watt is about half of CFL lamps.
Initially CCFL was used for thin monitors and backlighting, but **now it is
also manufactured for use as a lightbulb.** Since the efficacy (watt/lumen)
is actually lower than a compact fluorescent light, it is actually not as
efficient as a CFL. Its advantages are that it is (1) instant-on, like an
incandescent, (2) compatible with timers, photocells, and dimmers, and (3)
has an amazingly long life of approximately 50,000 hours. CCFL are a
convenient transition-technology for those who are not comfortable with the
short lag-time associated with the initial lighting of Compact Fluorescents.
They are also an effective and efficient replacement for lighting that is
turned on and off frequently with little extended use (e.g. a half-bath or
closet)."
** Emphasis mine
Bobby G.
Posted by Robert L Bass on March 23, 2007, 1:18 pm
Following are a few sources:
http://www.bosstar.com/ (appears to be a manufacturer)
http://www.mbelectronics.com (retailer)
http://www.maxim-ic.com/appnotes.cfm/appnote_number/3528 (application notes)
http://www.sunbeamtech.com/ (PC supplier)
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Posted by Robert Green on March 23, 2007, 3:14 pm
notes)
Thanks. These apparently are all long, small tubes. CCFL's are very popular
as laptop backlights but I have been looking all day for 110VAC screw-base
CCFL's to no avail. They sound very useful for lights controlled by motion
detectors and places where waiting for a CFL to come to full brightness
might be a safety issues, like staircases. We're due for another big rate
increase in the DC area and I'd like to find CFL's that work in the places
that have previously given me problems.
Bobby G.
Posted by Slammer on March 23, 2007, 4:12 pm
> notes)
> popular
> motion
> Bobby G.
READ the application notes above.
You won't find any 120VAC screw type CCFL. They need a step-up
transformer as they operate at 180-800VAC or higher. Since this is most
often a 2-3V source, the switching is done at 100KHz or higher. A
120:1200 VAC transformer with current limiting circuitry would be too
expensive. Beware some pwr supplies operate at 5,000VAC--so 300V
or 600V insulation is a no-no. I'd buy the wiring harness/set.
See
http://www.mbelectronics.com/view.aspx?id=260&name=Power%20Supplies%20,%20CCFL
or
http://www.solarlighting.com/cut_sheet_CCFL_transformer_model_5000.html
for pwr supply
http://www.coilcraft.com/pdfs/fl.pdf
for transformers and
http://www.mbelectronics.com/view.aspx?id=261&name=12"%20Cold%20Cathode%20Fluorescent%20Lamps%20,%20CCFL
for bulbs.
You might try:
http://www.ccfldirect.com/customlamps.html
What's wrong with LED's? They are intrinically safe.
Posted by Robert Green on March 23, 2007, 6:28 pm
> > notes)
> > popular
screw-base
> > motion
rate
places
> > Bobby G.
Sorry. I should have indicated why I was interested in the CCFLs. The
Wikipedia article strongly suggested such lamps were available in standard
formats, indirectly, I suppose, but here's what they said:
"Initially CCFL was used for thin monitors and backlighting, but now it is
also manufactured for use as a lightbulb"
A little further on they say "are also an effective and efficient
replacement for lighting that is turned on and off frequently with little
extended use (e.g. a half-bath or closet)."
That *sounds* like a screw-base standard lightbulb format, but they spell
some words with a British flavour so they may be talking about 240VAC mains.
> Since this is most
Dude, it's screw-in bulbs or screw it altogether! (-: I was attracted by
the claim:
"Advantages are that it is (1) instant-on, like an incandescent, (2)
compatible with timers, photocells, and dimmers, and (3) has an amazingly
long life of approximately 50,000 hours."
That would be a great bulb for the stairways and the bathroom. CFL's don't
last long when operated 40 times a day.
<stuff snipped>
> See
Thanks for the cites. I don't think I'm uninterested if it's not "plug
compatible" as the mainframers used to say. I was reading up on "choppers"
when I came across the description of the CCFL's as replacement for regular
CFL's and hoped someone out there was actually using one or knew where to
buy one.
Nothing. As far as I know. I wonder how they'll live with X-10? My
experience with early CFL's that required filters, $10 a bulb, modulectomies
AND that failed quite early inclines me NOT to be on the leading edge of the
LED lighting wave. (-: I did buy some great LED flashlights and emergency
lights recently because they are so miserly with battery power and lose no
energy to voltage conversion, but they still seem a little too weird,
lightwise. Maybe in time.
Bobby G.
Similar ThreadsPosted
Does anyone know who is making these light bulbs? March 23, 2007, 11:48 am
CF light bulbs and X10 modules July 23, 2007, 12:58 am
Making my own IR accessories July 12, 2008, 9:44 pm
Turn Your Computer Into A Money-making Machine April 20, 2005, 12:11 am
Low cost SMD Oven for making SMD samples and Prototypes July 11, 2006, 7:49 am
Making an X-10 lamp module immune to dimming June 4, 2008, 10:19 am
8051-class "learner" board - is it worth making one? May 11, 2006, 7:31 pm
fluorescent bulbs + x10 July 6, 2006, 1:56 am
Insteon & CF Bulbs December 17, 2006, 3:13 am
Halogen Bulbs mr16 November 19, 2005, 7:14 pm
Halogen Bulbs mr16 November 19, 2005, 7:17 pm
Insteon and dimmable CF bulbs November 25, 2005, 2:08 am
X10 and compact fluorescent bulbs January 27, 2006, 4:00 pm
LED bulbs that work with dimmers? March 13, 2007, 7:30 pm
AP story: " Australia to ban old-style bulbs " February 20, 2007, 12:00 pm
