Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Anthony R. Gold on August 4, 2007, 7:56 am
Please log in for more thread options This home uses wall switches such as dimming wall switch controllers HXC7S-1TW with dimming wall switch receivers HXM06-1TW to set scenes. Monitoring the power line X10 signals using an ACT monitor I see power line signals such as: K[1]012636 for scene 1 and K[1]01BE36 for OFF and when I use ACT's free Logger Interface software with one of their computer interface controller I can enter those same strings to correctly generate the appropriate scene commands. I have two problems: first I would like to control the individual lights and not only use the set scenes, and second I do not know how to have Homeseer software generate a K[1]012636 sequence, even if I was happy to live only with the scenes already set into the wall controller buttons. Any help or advice will be greatly appreciated. Tony | ||||||||||||||||
Posted by Dave Houston on August 4, 2007, 11:15 am
Please log in for more thread options "Cat. Nos. HCMØ6 and HCM1Ø can be operated manually as a standard type dimmer. The module may be set to any of 256 address codes, to be selected at the time of installation. The desired address is set by depressing and holding the recessed button until the ON/OFF LED flashes. The code is then learned from any transmitter when it sends the DHC command." | ||||||||||||||||
Posted by Anthony R. Gold on August 4, 2007, 11:55 am
Please log in for more thread options On Sat, 04 Aug 2007 15:15:26 GMT, nobody@whocares.com (Dave Houston)
wrote: > http://www.smarthome.com/manuals/4289&4292.pdf
> > "Cat. Nos. HCMØ6 and HCM1Ø can be operated manually as a standard type > dimmer. The module may be set to any of 256 address codes, to be selected at > the time of installation. The desired address is set by depressing and > holding the recessed button until the ON/OFF LED flashes. The code is then > learned from any transmitter when it sends the DHC command." Thanks. But does anyone know how to discover which address code a receiver has learnt during that setup method? Tony | ||||||||||||||||
Posted by Dave Houston on August 4, 2007, 1:40 pm
Please log in for more thread options It learns the first code transmitted after it is put into programming mode.
>wrote: > >> http://www.smarthome.com/manuals/4289&4292.pdf
>> >> "Cat. Nos. HCMØ6 and HCM1Ø can be operated manually as a standard type >> dimmer. The module may be set to any of 256 address codes, to be selected at >> the time of installation. The desired address is set by depressing and >> holding the recessed button until the ON/OFF LED flashes. The code is then >> learned from any transmitter when it sends the DHC command." >
>Thanks. But does anyone know how to discover which address code a >receiver has learnt during that setup method? > >Tony | ||||||||||||||||
Posted by Anthony R. Gold on August 4, 2007, 2:17 pm
Please log in for more thread options On Sat, 04 Aug 2007 17:40:30 GMT, nobody@whocares.com (Dave Houston)
wrote: >
>> wrote: >> >>> http://www.smarthome.com/manuals/4289&4292.pdf
>>> >>> "Cat. Nos. HCMØ6 and HCM1Ø can be operated manually as a standard type >>> dimmer. The module may be set to any of 256 address codes, to be selected at >>> the time of installation. The desired address is set by depressing and >>> holding the recessed button until the ON/OFF LED flashes. The code is then >>> learned from any transmitter when it sends the DHC command." >>
>> Thanks. But does anyone know how to discover which address code a >> receiver has learnt during that setup method? > It learns the first code transmitted after it is put into programming mode.
Yes, and that was clear from the documentation and stated in your earlier. But when the switch receiver learnt its code from wall switch controllers which sent extended codes of the type I listed before such as K[1]012636, how does one determine which simple X10 code will operate it? And/or how does one set up Homeseer or any other X10 compatible software to generate such extended codes? I am asking particularly whether anyone has any experience of doing this and whether they would explain how they did it. Tony | ||||||||||||||||
| Similar Threads | Posted |
| Computer Control over Leviton Green Series Components | August 4, 2007, 7:56 am |
| x10 control from computer | November 19, 2005, 11:52 am |
| remote control for my computer | August 13, 2007, 5:48 pm |
| Computer control of an audio multiplexor | December 2, 2007, 3:14 pm |
| Automation Panel vs. Components | July 14, 2005, 7:33 pm |
| The Green Glue Phenomenon | March 5, 2007, 12:23 am |
| Re: Does leviton make anything better than the leviton 6381 that ramps up from 0% when turned on? | November 3, 2005, 9:41 pm |
| Q: On Q vs Leviton | December 3, 2006, 2:03 am |
| Leviton QuickPort RCA | April 29, 2005, 11:59 pm |
| Leviton and DirecTV | July 2, 2005, 12:57 pm |
| Leviton Intellisense Vs Others | January 12, 2006, 3:03 pm |
| Leviton HCA02-10E | June 18, 2006, 7:26 pm |
| Leviton and Lutron | August 9, 2006, 12:17 pm |
| Bridging Module ?? (Leviton) | March 25, 2005, 10:01 pm |
| Leviton 49660 Stripper | June 11, 2007, 1:51 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>Tony
