General Home Automation CFL's & Electronic Ballast bad???
Subject Author Date
CFL's & Electronic Ballast bad??? ABLE_1 01-02-08
Posted by ABLE_1 on January 2, 2008, 1:02 pm
Hello all,
Looking for a little insight. I heard today from an electrician that there
is some issue with CFL's and Electronic Ballast in that they are causing
reception problems with radios.
What he has told me is that at some another location after installing some
new lights that use electronic ballast, the employees there cannot get the
radio to pull in any stations with out turning off the lights. He said that
he has heard that CFL's do the same thing.
Soooooooooooooooo since this is the first time I have heard of this I
thought I would post the query here. Because if anybody know anything about
this phenomenon somebody here will post back some input.
It is very possible that this is well known and I did not get the
memo................................
So the floor is open for discussion.
Thanks in advance to all.
Les
Posted by Dave Houston on January 2, 2008, 1:32 pm
My guess is he was talking about a commercial installation. Newer
high-efficiency electronic ballasts used with straight fluorescent tube
lights can put out a lot of EMI/RFI but these are not all rated for
residential use (per the FCC).
While there have been many reports of conducted CFL noise interfering with
X-10 and Insteon lights, I haven't seen any reports of radiated noise
causing significant interference to radio reception or blocking IR remotes.
Of course, given the lack of enforcement of FCC technical rules, it's always
possible that there may be some CFLs that do put out high levels of EMI and
RFI.
Anything that meets FCC Class B limits (residential) should be OK and most
CFLs are probably rated for residential use.
http://www.gelighting.com/na/business_lighting/education_resources/literature_library/ballast/downloads/71881_resi_proline_T8.pdf
>Hello all,
>Les
http://davehouston.net http://davehouston.org
http://tech.groups.yahoo.com/group/roZetta/
roZetta-subscribe@yahoogroups.com
Posted by Ghost on January 2, 2008, 2:05 pm
> Hello all,
> there is some issue with CFL's and Electronic Ballast in that they are
> causing reception problems with radios.
> that he has heard that CFL's do the same thing.
> about this phenomenon somebody here will post back some input.
Just try to avoid cheap chinese lights and all should be OK. They cut costs
in way that causes more noise etc. However I don't think that there could be
problems with radio reception - even with cheapest products. Your electrican
probably has no knowledge in this area.
Similar ThreadsPosted
CFL's & Electronic Ballast bad??? January 2, 2008, 1:02 pm
OT: electronic locks August 12, 2008, 5:03 am
OT: electronic locks August 19, 2008, 7:41 pm
Electronic Design Technology EDT April 2, 2005, 3:37 pm
PIC Projects Update for Electronic Kit Zoo as of Feb 26, 2005 February 26, 2006, 2:06 pm
Result of search for KIT>ELECTRONIC HOBBY KIT August 5, 2007, 4:08 am
Search for electronic plan to build x-10 interface for pc February 20, 2005, 7:01 am
Re: Home Automation and Electronic Internet "Porch Sale" September 22, 2007, 4:20 pm
Re: CFL's and X-10 June 15, 2008, 7:21 am
Re: CFL's and X-10 June 23, 2008, 3:00 pm
N:Vision CFL's March 24, 2007, 5:42 am
