Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Brian S. Schang on March 1, 2006, 7:13 am
Please log in for more thread options To make a long story short, I've had much success using X-10 for lighting control. Although I have a smaller house, I have made sparing use of Leviton plug-in filters (I forget the model number) for the electrical devices I have that tend to attenuate the X-10 signals. I try to be cognizant of the devices I add so that I can pinpoint a problem when it occurs. I've been fairly successful. Now, however, I'm in a project to finish my basement. I'm staring to get flakey X-10 behavior, and I know exactly where the problems are. I've moved my computers from upstairs to the basement and have not reinstalled the filters yet. I'm sure that if I were to reinstall them my problems would go away. Here is my question ... is this really the best way to handle this problem? While I've been successful using these filters, I have friends and family that have been equally successful using repeaters and amplifiers. Which is the most robust solution? I ask simply because as I finish the basement, I'll either need to buy more filters or buy another solution, such as a repeater or amplifier. I want to try to put my money towards the most robust solution. While I don't want to throw money away, I'm willing to spend more to get a better solution. Lastly, and I really don't know what I'm talking about here, are there any issues with repeaters and/or amplifiers with extended X-10 codes? To be honest, I'm not sure if I even use extended codes right now, but if I am, I don't want to loose that functionality. Are there any issues that I need to be aware of? Thanks for listening and for any advice that you may be able to offer. -- Brian Schang | ||||||||||||||||||||||||||||
Posted by Dave Houston on March 1, 2006, 7:56 am
Please log in for more thread options noise worse. | ||||||||||||||||||||||||||||
Posted by Neil Cherry on March 1, 2006, 10:04 am
Please log in for more thread options On Wed, 01 Mar 2006 12:56:11 GMT, Dave Houston wrote:
>>get flakey X-10 behavior, and I know exactly where the problems are. >>I've moved my computers from upstairs to the basement and have not >>reinstalled the filters yet. I'm sure that if I were to reinstall >>them my problems would go away. >> >>Here is my question ... is this really the best way to handle this >>problem? While I've been successful using these filters, I have >>friends and family that have been equally successful using repeaters >>and amplifiers. Which is the most robust solution? > Filters help with both noise and signal sinks while amplifiers may make
> noise worse. Dave's correct, I have an errant signal sucker (can't find it yet, busy doing other thing) and an amp. Luckily the amp/repeater doesn't appear to repeat the noise. It does detect noise (hours worth) but I don't see it on both sides of the 2 2 'phases'. The X10 works OK most of the time but I sometimes lose an on or off. I then have to fix it manually. -- Linux Home Automation Neil Cherry ncherry@linuxha.com http://www.linuxha.com/ Main site http://linuxha.blogspot.com/ My HA Blog http://home.comcast.net/~ncherry/ Backup site | ||||||||||||||||||||||||||||
Posted by BruceR on March 1, 2006, 4:42 pm
Please log in for more thread options I agree that if filters do the job you should forego the repeaters.
Adding the repeater will not eliminate every filter. In my case, I have both. > Hello:
> > To make a long story short, I've had much success using X-10 for > lighting control. Although I have a smaller house, I have made sparing > use of Leviton plug-in filters (I forget the model number) for the > electrical devices I have that tend to attenuate the X-10 signals. I > try to be cognizant of the devices I add so that I can pinpoint a > problem when it occurs. I've been fairly successful. > > Now, however, I'm in a project to finish my basement. I'm staring to > get flakey X-10 behavior, and I know exactly where the problems are. > I've moved my computers from upstairs to the basement and have not > reinstalled the filters yet. I'm sure that if I were to reinstall > them my problems would go away. > > Here is my question ... is this really the best way to handle this > problem? While I've been successful using these filters, I have > friends and family that have been equally successful using repeaters > and amplifiers. Which is the most robust solution? > > I ask simply because as I finish the basement, I'll either need to buy > more filters or buy another solution, such as a repeater or amplifier. > I want to try to put my money towards the most robust solution. While > I don't want to throw money away, I'm willing to spend more to get a > better solution. > > Lastly, and I really don't know what I'm talking about here, are there > any issues with repeaters and/or amplifiers with extended X-10 codes? > To be honest, I'm not sure if I even use extended codes right now, but > if I am, I don't want to loose that functionality. Are there any > issues that I need to be aware of? > > Thanks for listening and for any advice that you may be able to offer. | ||||||||||||||||||||||||||||
Posted by Brian S. Schang on March 2, 2006, 9:56 pm
Please log in for more thread options On Wed, 01 Mar 2006 07:13:18 -0500, Brian S. Schang
>lighting control. Although I have a smaller house, I have made sparing >use of Leviton plug-in filters (I forget the model number) for the >electrical devices I have that tend to attenuate the X-10 signals. I >try to be cognizant of the devices I add so that I can pinpoint a >problem when it occurs. I've been fairly successful. > >Now, however, I'm in a project to finish my basement. I'm staring to >get flakey X-10 behavior, and I know exactly where the problems are. >I've moved my computers from upstairs to the basement and have not >reinstalled the filters yet. I'm sure that if I were to reinstall >them my problems would go away. > >Here is my question ... is this really the best way to handle this >problem? While I've been successful using these filters, I have >friends and family that have been equally successful using repeaters >and amplifiers. Which is the most robust solution? > >I ask simply because as I finish the basement, I'll either need to buy >more filters or buy another solution, such as a repeater or amplifier. >I want to try to put my money towards the most robust solution. While >I don't want to throw money away, I'm willing to spend more to get a >better solution. Thanks for all of the good feedback. Seems unamimous in that filters would be a better choice than repeaters/amplifiers since I have been successful with the filters in the past. The only potentially complication is that when moving my computers downstairs I upsized my UPS. I have a 1000W unit now which exceeds my filter's rated capacity of 120V and 5A (600W). I have been using Leviton model 6288 filters. Given that I need more capacity, are there any filters that will work? If not are there any good alternate options? Thanks again for the help. Brian Schang | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Best Way to Amplify X-10 Signal? | March 1, 2006, 7:13 am |
| X10 signal levels | July 28, 2005, 2:05 pm |
| X10 signal problems... | October 18, 2005, 10:48 am |
| mystery signal | November 11, 2005, 11:02 am |
| X10 to Wireless signal | July 20, 2007, 8:26 pm |
| X10 signal amplitude | September 13, 2008, 4:53 am |
| CVBS video signal | April 4, 2005, 3:08 pm |
| Measuring X10 Signal Strength. | May 25, 2005, 8:53 pm |
| is it possible for x10 signal bridge to fail? | August 6, 2005, 9:32 pm |
| Signal bridge question? | December 21, 2005, 2:11 pm |
| a phantom signal source | December 6, 2007, 8:06 am |
| Splitting a CCTV signal to two monitors | May 4, 2005, 1:16 pm |
| Need to very good booster X10 signal on both phases? | June 28, 2005, 5:46 am |
| IOSOBAR Ultra for a UPS signal sucker? | July 11, 2005, 12:36 am |
| X-10 Mystery - An Anti-Signal Sucker | August 23, 2005, 12:56 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>better solution.
