General Home Automation Audio Video Distribution Questions
Subject Author Date
Audio Video Distribution Questions vnegri 10-21-05
Posted by on October 21, 2005, 9:54 am
I am planning to use a Russound CAV6.6 to distribute different sources
(audio and video) to different rooms in a house. We are planning to run
2 Cat5e and 1 RG6 to each room. Do I need to have to purchase separate
RF modulators for each zone to convert the rca jacks coming out of the
CAV6.6 to coax or is there a better way? (The homeowner does not want
to place in-wall speakers in every room and wants to use the TV's
built-in speakers). What brand of RF modulator would you recommend?
Posted by wkearney99 on October 21, 2005, 1:21 pm
If the TVs take video and audio inputs then just run that from the CAV66.
Bearing in mind that you'll need to lower the speaker level signals to line
level, russound sells units to do that. The only tricky part would be
volume control, the keypad would have to be left at a given volume level
into order to have the live level converter pick it up and feed it to the
TV. Not a big deal though, the homeowner would just have to get used to it.
You'd still need the line level converters with an RF modulator. The only
time you'd need to use an RF modulator would be for a TV that doesn't have
video inputs.
One other trick to consider if you've got more than one video device is to
use multiple channels over RF. I feed a DirecTV Tivo, DVD player and a VCR
into RF channels and the pass that around the house. All the TVs get the RF
(in addition to the CAV66 on video) so I can easily watch whatever's on the
other devices independently of CAV66 control. This makes it easy to listen
to the radio over the in-ceiling speakers while also watching the TV, or
flip between Tivo video via CAV66 and RF over-the-air stations. But then
most folks probably won't want to bother with this much flexibility as it
/can/ get a little confusing to go flipping around TV stations and the video
inputs.
So if you've got TVs that take video and l/r audio directly then you don't
need a modulator at all.
-Bill Kearney
Posted by on October 21, 2005, 12:02 pm
I know there's a way to convert an a-bus signal into line-level rca for
audio. I could probably do that to get audio to the TV. Now my question
is with video. I would have to hook the coax to the back of the TV to
get the cable feed and then use some form of converter to change the
rca outputs from the CAV6.6 into coax or ethernet to be sent to the
room and then convert it back again... right? Then in order to switch
between live TV and the CAV6.6, I would have to use the input selector
on the TV. What converter should I use?
My other option is to convert A-Bus to rca audio in the distribution
closet and then push those signals with the video out from the CAV6.6
into an RF Modulator (if this is the correct way). I could take the
output from the RF Modulator and use a combiner with the cable feed to
send a signal over RG6 to each room. But this way, I would have to
purchase a separate RF Modulator for each zone.
What is the best design to get live cable and a signal from the CAV6.6
to each room if I don't want to have in-wall speakers? Please detail
the different converters I would need to use to utilize the RG6 and
Cat5e runs to each room (I think that's where I'm stuck).
Posted by E. Lee Dickinson on October 21, 2005, 4:34 pm
If you're using RG6 to send just a composite video signal (not modulated
audio/video), then all you need to do is crimp RCA connectors to it instead
of Coax, or get some screw-on Coax/RCA adaptors. IE, turn the RG6 into a RCA
cable, connect one ende to the vid out of the CAV6.6, the other end to the
Vid IN of the TV. You'd then connect normal modulated cable signal to the
coax in of the TV. Your AV input would be the CAV, your cable input would be
cable tv.
Posted by wkearney99 on October 21, 2005, 4:42 pm
Only if your TV can't take video input. The CAV distributes video, not RF.
Plug the cable RF into the TV like usual. Then plug the CAV signals into
the TV's video and l/r audio jacks. Assuming, of course, that you're using
a line-level adapter on the audio.
There's no A-Bus involved here. That's a whole other thing.
Then when you want to jump between RF cable and the CAV signal you just
change the 'input' source on the TV. Most TVs do this with a "TV/Video"
button on the remote.
No converters involved.
And if you've got digital cable then you'd, of course, have to attach the
cable box to the incoming digital cable signal and then into the TV. Either
via RF or feed the video from the CAV into the digital cable box and use
it's input mode switcher.
Again, where's A-Bus here? That's not how the CAV66 sends things around.
There are 4 A-bus slave ports but they're not how the main 6 zones handle
things.
I already explained this. What might not be clear is you have TWO sets of
coax going into the room. One is for the cable's own signal and the other
is for the CAV66 video. What might be confusing to you is the CAV's video
signal is a regular video signal, not an RF modulated one. You need the
right wall plate connections of course.
-Bill Kearney
Similar ThreadsPosted
Audio Video Distribution Questions October 21, 2005, 9:54 am
Audio / Video Distribution October 13, 2005, 11:19 am
distribution of HTPC's VIDEO + AUDIO April 3, 2005, 6:14 pm
Home video distribution? March 21, 2005, 3:21 am
Video Server and Distribution June 12, 2006, 11:22 pm
Home RF video distribution November 7, 2006, 7:04 pm
Distribution of video signal to multiple TV using a matrix April 3, 2007, 5:39 pm
Crestron plans for digital video distribution? June 17, 2008, 9:28 am
Zon Audio distribution question April 24, 2005, 8:56 am
Help: home audio distribution scheme April 30, 2006, 12:16 am
Whole House Audio/Video August 20, 2005, 3:21 pm
audio video multimedia setup August 22, 2006, 10:38 pm
X10 questions December 30, 2005, 3:03 pm
Couple of New Guy Questions February 27, 2005, 12:27 am
Newbie Questions May 19, 2005, 11:10 am
