General Home Automation ActiveHome Pro, Remote Controls, and Appliances
Subject Author Date
ActiveHome Pro, Remote Controls, and Appliances donquixote235 11-10-05
Posted by donquixote235 on November 10, 2005, 10:26 pm
I just got an X10 kit today, and I've been playing with it all night. I've
got a problem that's pretty frustrating, and I can't really find anything
pertinent on the web.
Whenever I use any of the three remotes supplied with the kit (HR12A
remote, SS13A StyleSwitch, KR19A slimfire remote) to try to turn on my lamp
module, the ActiveHome software recognizes the signal, and "throws" the
graphical image of the lightswitch into the on or off position as the case
may be. However the light doesn't actually come on or go off. If I click
the switch graphic using my mouse button, the light works fine.
I thought it may have been a line-of-sight issue at first, but I've put the
remote mere inches away from the lamp module, and from the ActiveHome
module as well. Again, the same problem... the main module recognizes it,
but the lamp module won't. I also tried changing from the lamp module to a
screw-in module, and to an appliance module, all with the same degree of
suggess, i.e. none. In every case, the software recognizes the remote, but
the appliance won't.
Any help or guidance would be greatly appreciated.
-Scott
Posted by E. Lee Dickinson on November 10, 2005, 11:55 pm
> Hi,
> I've
> lamp
Scott --
The system works by recieving the RF (remote) signal, and then broadcasting
a command over the power line. So proximity of the remote to the activehome
reciever is of importance, not proximity to the lamp module.
The distance between the lamp module and the reciever -- electrically
speaking moreso than physically speaking -- could cause your issue. Try
plugging the lamp and the reciever into the same circuit in your home, and
let us know the results.
E. Lee Dickinson
Entertainment Design and Technology
Posted by E. Lee Dickinson on November 11, 2005, 1:05 am
Also -- make sure the modules are set to the same house code and unit code
you're broadcasting...
Posted by Dave Houston on November 11, 2005, 6:11 am
You need to select the housecodes to be "tranceived" and store them in the
interface.
>Hi,
>-Scott
Posted by random735 on November 11, 2005, 9:16 am
I think you guys may have missed that he said clicking the graphic in
ActiveHome works.
So clearly ActiveHome is able to activate the module. And it's
receiving the signal from
the RF telling it to activate the module.
At least that's how I read his message.
Sounds pretty weird to me.
Similar ThreadsPosted
ActiveHome Pro, Remote Controls, and Appliances November 10, 2005, 10:26 pm
X10 activehome remote control - need manual August 14, 2006, 8:06 pm
New HAI lighting controls March 27, 2005, 12:44 am
Integrating Hot Tub controls April 26, 2005, 2:15 am
Pool controls - what are my options? February 6, 2005, 9:42 am
ONq Amplified volume controls October 27, 2006, 5:01 pm
Help Installing Speaker Volume Controls ... December 24, 2005, 10:22 am
HVAC Actuator controls (4-20mA or 0-10V?) June 29, 2007, 1:54 pm
Leviton "Air Gap Switch" on Dimmer Controls July 2, 2008, 12:41 pm
reseting misterhome light controls after poweroutage December 5, 2007, 10:09 pm
Activehome March 27, 2005, 5:26 pm
x10 activehome pro January 26, 2007, 11:02 am
Does ANYONE Still Use the CM11A w/ActiveHome? April 12, 2005, 9:51 pm
Activehome ProCM15A on a Mac? November 13, 2005, 8:48 am
Tired of Activehome... October 30, 2006, 6:03 pm
