I'm having a hard time trying to control a eletromagnetic relay with the 1-wire. I have controlled SSR with no problems whatsoever. With the eletromagnetic relay. I use a ds2405, pnp transistor 1k resistor and a
10k resister and a diode. Everything works until I hook plug in 120v. Then I get an error "Failure to change ds2405 latch state". And sometimes Cannot Communicate with device. These errors wouldnt bother me because the device does turn on. But it causes other relays to turn off breifly when I switch on a relay with 120v going to the relay.. Note that the relays work flawlessly without any errors. Until I hook up the 120v. Even if there is no load. Just plugging in the 120v makes it receive this breif error. Anyone have any ideas??Xavier
