ZyXel Command Interpreter
Hello
Following some splendid advice (ip nat loopback on) I found published in this group my colleague is now a happy bunny. However ....
Router: ZyXel P650R-31
Issue: Command Interpreter commands are lost with power recycle.
Q: How to make CI settings persist through power reset?
Many thanks.
William Tasso
You need to add the command to the autoexec file, have a look at this link
Although it describes the MTU setting it tells you how to add a command to the autoexec.net file.
HTH
Regards
Bill
phoenix
Cheers - that seems to do the job.
William Tasso
