Zonealarm and sniffer tools
I would like to analyze the internet communication by using a sniffer program, however, when Zonealarm is running, all sniffers I tried are only tracking incoming packets. Is there a way to record also the outgoing packets without deactivating Zonealarm? I use Windows 2000 with Service Pack 4. Thank you very much in advance.
ua
Sounds like you have a filter setup on the sniffer. It should catch both ways.
A good and free sniffer is wireshark.
Robert
Am Sat, 16 Dec 2006 15:57:09 +0100 schrieb Robert :
Thanks, it works :-) It seems the error was caused by a missing "WinPCap" driver. The other tools I had tried before did not automatically install that driver and then run in the "raw ip" mode. Probably this was the reason why they could only track the incoming packets.
ua
