zone alarm start up
I wonder if someone can help me. When I start my machine up I get a `Zone alarm pop up security alert` Server Program saying Generic Host Process for Win32 Servers is trying to act as a server
Identification: None Application: sychost.exe Source IP: 0.0.0.0.Port 135
if I do either, click on the button `remember this setting.`Allow` or `Deny` Zone Alarm then starts up and my machine works OK. The trouble is it will still pop up next time I boot up so its getting to be a pain. Any ideas how to stop this popping up every time.
Thanks
Ken
Ken Walsh
That's easy. Uninstall ZA. You don't need it anyway.
Root Kit
Chris
Chris Davies
Looks like HE does. Unless he's ignoring other virus indicators.
Eric
Eric Parker
If the name of the application really is sychost.exe not svchost.exe then it's a bit late to replace the useless firewall software with a somewhat useful virus scanner. You will need to back up any wanted files and reinstall the operating system and everything else from clean media.
If, as I suspect, you meant svchost.exe then your best plan is to remove the useless firewall software and install a virus scanner if you don't already have one. Make sure the windows firewall is turned on. If you want a free virus scanner try
but a paid one is best because you might otherwise still be troubled by nag popups asking you to buy a virus scanner.
Network Admin
My point exactly.
Root Kit
Sorry my mistake I went and checked again after reading the replies and like an idiot I am (blind as a bat as well) yes your right it is SVCHOST.EXE and not sychost.exe
Ken Walsh
