Hello,
I have an issue with a VPN tunnel that has worked fine for 4 years until this week. The tunnel is a one way tunnel. The boxes are both Watchguard 700's. Ping is enabled on the remote firewall. When I ping the trusted interface on the remote box, 10.x.x.253, it responds. When I ping the machine 10.x.x.140 no respond. The machine is on and functioning. Now I noticed some wired things in the logs. Here are the logs from the remote firebox:
04/12/08 18:18 iked[133]: FROM 66.184.x.x IF-HDR* -C9279D04 ISA_HASH 04/12/08 18:18 iked[133]: Received a packet for an unknown SA 04/12/08 18:21 dvcpd[119]: opening dvcp server 66.184.x.x with client id DGJ 04/12/08 18:21 dvcpd[119]: Read error from 66.184.x.x : Connection refused 04/12/08 18:21 dvcpd[119]: config file has not changed since last dvcp update 04/12/08 18:21 dvcpd[119]: server will be contacted in 1800 seconds 04/12/08 18:21 iked[133]: FROM 66.184.x.x IF-HDR* -5B98261D ISA_HASH 04/12/08 18:21 iked[133]: Received a packet for an unknown SA 04/12/08 18:22 iked[133]: FROM 66.184.x.x MM-HDR ISA_SA ISA_VENDORID ISA_VENDORID ISA_VENDORID ISA_VENDORID 04/12/08 18:22 iked[133]: TO 66.184.x.x MM-HDR ISA_SA ISA_VENDORID ISA_VENDORID 04/12/08 18:22 iked[133]: FROM 66.184.x.x MM-HDR ISA_KE ISA_NONCE NAT-D NAT-D 04/12/08 18:22 iked[133]: TO 66.184.x.x MM-HDR ISA_KE ISA_NONCE NAT-D NAT-D 04/12/08 18:22 iked[133]: CRYPTO ACTIVE after delay 04/12/08 18:22 iked[133]: FROM 66.184.x.x MM-HDR* ISA_ID ISA_HASH 04/12/08 18:22 iked[133]: TO 66.184.x.x MM-HDR* ISA_ID ISA_HASH 04/12/08 18:22 iked[133]: FROM 66.184.x.x IF-HDR* -43BD09B5 ISA_HASH ISA_NOTIFY 04/12/08 18:22 iked[133]: Received INITIAL_CONTACT message, mess_id=0xB509BD43 04/12/08 18:22 iked[133]: FROM 66.184.x.x QM-HDR* -5D1E747E ISA_HASH ISA_SA ISA_NONCE ISA_ID ISA_ID 04/12/08 18:22 iked[133]: TO 66.184.x.x QM-HDR* -5D1E747E ISA_HASH ISA_SA ISA_NONCE ISA_ID ISA_ID 04/12/08 18:22 iked[133]: FROM 66.184.x.x QM-HDR* -5D1E747E ISA_HASH 04/12/08 18:22 iked[133]: Load outbound ESP SA, Algs=ESP_DES/ AUTH_ALG_HMAC_SHA1 Life=0sec/0KB SPI=1404194A 04/12/08 18:22 iked[133]: Load inbound ESP SA, Algs=ESP_DES/ AUTH_ALG_HMAC_SHA1 Life=0sec/0KB SPI=12042074 04/12/08 18:22 iked[133]: Tunnel created for 10.x.x.0/24 10.x.x.0/14 04/12/08 18:22 kernel: ipsec: make bundle for channel 14, 1 in SA's, 1 out SA's 04/12/08 18:25 iked[133]: FROM 66.184.x.x IF-HDR* -5E28E4FC ISA_HASH ISA_NOTIFY 04/12/08 18:25 iked[133]: Received KEEPALIVE_REQUEST message, mess_id=0xFCE4285E 04/12/08 18:25 iked[133]: Sending KEEPALIVE_ACK message 04/12/08 18:25 iked[133]: TO 66.184.x.x IF-HDR* -7CD567A1 ISA_HASH ISA_NOTIFY 04/12/08 18:25 iked[133]: TO 66.184.x.x IF-HDR* -7CD567A1 ISA_HASH ISA_NOTIFY 04/12/08 18:28 iked[133]: FROM 66.184.x.x IF-HDR* -0E19F640 ISA_HASH ISA_NOTIFY 04/12/08 18:28 iked[133]: Received KEEPALIVE_REQUEST message, mess_id=0x40F6190E 04/12/08 18:28 iked[133]: Sending KEEPALIVE_ACK message 04/12/08 18:28 iked[133]: TO 66.184x.x IF-HDR* -E675CDAD ISA_HASH ISA_NOTIFY 04/12/08 18:31 iked[133]: FROM 66.184.x.x IF-HDR* -0762ACC7 ISA_HASH ISA_NOTIFY 04/12/08 18:31 iked[133]: Received KEEPALIVE_REQUEST message, mess_id=0xC7AC6207 04/12/08 18:31 iked[133]: Sending KEEPALIVE_ACK message 04/12/08 18:31 iked[133]: TO 66.184.x.x IF-HDR* -55D1BF24 ISA_HASH ISA_NOTIFY 04/12/08 18:34 iked[133]: FROM 66.184.x.x IF-HDR* -459D6CAB ISA_HASH ISA_NOTIFY 04/12/08 18:34 iked[133]: Received KEEPALIVE_REQUEST message, mess_id=0xAB6C9D45 04/12/08 18:34 iked[133]: Sending KEEPALIVE_ACK message 04/12/08 18:34 iked[133]: TO 66.184.x.x IF-HDR* -FE956D35 ISA_HASH ISA_NOTIFY 04/12/08 18:37 iked[133]: FROM 66.184.x.x IF-HDR* -2460B6DE ISA_HASH ISA_NOTIFY 04/12/08 18:37 iked[133]: Received KEEPALIVE_REQUEST message, mess_id=0xDEB66024 04/12/08 18:37 iked[133]: Sending KEEPALIVE_ACK message 04/12/08 18:37 iked[133]: TO 66.184.x.x IF-HDR* -5F5BE769 ISA_HASH ISA_NOTIFYI'm thinking it's an encryption problem, but I'm not sure.
Thanks for any help
