VPN<-->VPN via hub (Sonicwall & Draytek) help
Hi
We have a sonicwall pro 2040 enhanced OS hub, and draytek vpn remote routers.
VPN is set up fine and works well for traffic from remote VPN to hub.
But - we want VPN to talk to VPN.
e.g.: Hub 192.168.1.0/24 Site1 192.168.2.0/24 Site2 192.168.3.0/24
The drayteks are set up to know the hub and the other site networks are available over the VPN.
Pinging 192.168.3.1 from site1 sends the packet over the VPN - but then gets lost (or appears to). Pinging 192.168.4.1 from site1 and the packet goes to the router default gateway and fails (obviously). Bascially, this says to us that the draytek is configured okay,.
The sonicwall should have the right config to allow VPN to VPN site connections.
We have followed the documentation sent by Draytek and Sonicwall tech support.
Not much config onteh drayteks, and draytek say it looks okay.
Sonicwall tech support say quote: "Sir, First of all, we normaly do not support 3rd party VPN's. Anyway this don't seams to be a Sonicwall issue....."
Does anyone have this setup working? Any tips or thoughts?
I can provide more information if required.
MANY THANKS!
(PS do not email direct - this email address is not in use)
ryanjjones
How?
There are 3 basic issues here.
  1. The tunnels must be set up with Proxy-ID's that support both remote networks. Otherwise those packets will not be able to travel over the tunnel regardless of what is done at each end. Different boxes support one or more of these methods: a) Two phase 2's bound to a single phase 1, each of which supports a different /24 to cover both remote sites b) One phase 2 with proxy ID's with a wider netmask to include all remote networks -- in this case site 2 can use 192.168.1.0/23 but site 2 can only use 192.168.0.0/22, which will encompass 1 extra network *and* the local addresses which it should be smart enough not to put in the tunnel... this is likely a problematic method. c) Open or wildcard proxy id's of 0.0.0.0/0 to allow anything in each tunnel, controlled then by some other sort of routing on the box. Your best bet option. Sites will need to be either static IP's or will need an extra identifier to facilitate tunnel selection at the hub.
  1. Once the correct proxy ID's are specified, each site box must know how to put only the correct traffic into the tunnel (especially with option c above)
  2. The hub must know how to route traffic that comes out of one tunnel, in to another tunnel, and the reverse, when appropriate.
You will have to have addressed all threee of these issues in order to succeed at this hub-and-spoke vpn.
More detail please. traceroute to 192.168.4.1, should hop out the internet and die there, not die at the gateway. From any site.
Try traceroute 192.168.3.1 from site1, does it die at site2 gateway (bad tunnel) hub gateway (bad step 3 above) or site 2 gateway (bad step 2 above at site 2)?
Same test from site2...
-Russ.
Somebody.
