Is there a version of VNC that can display the entire remote screen in reduced size, so you can load up your screen with an array of remote screens?
- posted
19 years ago
Taking a moment's reflection, Tom Del Rosso mused: | | Is there a version of VNC that can display the entire remote screen in | reduced size, so you can load up your screen with an array of remote | screens?
I believe all versions have the ability to scale the screen. Real and TightVNC scale by "fraction" (i.e. 1/4, 1/2, or 7/8) ... UltraVNC can scale by percentage or fraction.
Thanks. I knew I had seen it. But I took another look at the viewer in action and I still don't see the option, then I googled and found this:
Taking a moment's reflection, Tom Del Rosso mused: | | So they actually dropped the feature! The problem then is that I'm always | using the "real" thing, but now I'll try Ultra.
Seems strange that they dropped it. Honestly, I haven't used RealVNC since v3.3.6 ... which is when I discovered UltraVNC. File transfers, encryption via plugin, and MS Logon authentication ... and still free! ;-)
