Is Windows Vista (32bit) firewall regarded as a good firewall?
Thanks
Thanks
species8350 wrote in news:27730ebf-3317- snipped-for-privacy@k36g2000pri.googlegroups.com:
sort of depends on what you want it to do.
Firewalls are not good or bad (usually). Policies are good or bad. Is the default windows vista firewall policy good? depends on your setup.
You are not going to find anything better than the Vista FW and Vista in itself due to the advanced features the FW and Vista are using.
Jesper's Blogs- At Least This Snake Oil Is Free.
Tap into the Vista firewall's advanced configuration features
