I have Google Desktop Search installed and it claims to be able to index my Gmail mail as well, if only it could connect via port 995 to Gmail.
Well, I run Norton Internet Security (NIS) 2005 and frankly, I don't understand this. Shouldn't Google Desktop get access to port 995 just like any other program get access to a port, just by attempting to use the port? A warning should then come up and I should be able to say "Yes/No".
So I investigate a little bit and places like GRC.com says port 995 is stealthed. And I'm thinking perhaps the connection is the other way round and if I open port 995 to gmail then my indexing will take place. I create a rule that says to allow inbound and outbound connections on port 995 if the traffic is to/from google.com, gmail.com and GRC.com (to test). On testing, all I get is a bunch of warnings that NIS has blocked the port due to it being "unused" - it seems if there is not a program that have actively opened a port, then NIS will still block traffic to that port.
So I thought I would ask those that perhaps understand firewalls better than I do (I'm in the GWF league) if I misunderstood the situation, should have done something different or if the problem might be elsewhere?
Thanks in advance, MikeB
