Hi all
I have a problem with my PIX 515 firewall.
Sometimes the traffic just stop passing for a period of time. It can bee for 20-40 minutes.
If I log on to the PIX via serial interface, I can see it's running, but I can't ping clients on the inside or the outside.
If I don't touch anything, the traffic will start passing agin after sometime.
How do I trace down this problem?
My PIX info:
------------------------------------------------------ Cisco PIX Firewall Version 6.3(3) Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz Flash i28F640J5 @ 0x300, 16MB BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54ff.45fa, irq 10 1: ethernet1: address is 0050.54ff.45fb, irq 7 Licensed Features: Failover: Enabled VPN-DES: Disabled VPN-3DES-AES: Disabled Maximum Physical Interfaces: 6 Maximum Interfaces: 10 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited Serial Number: 480130143 (0x1c9e345f)------------------------------------------------------
Regards /Romme
