I am using Kaspersky Anti-Hacker version 1.8.180.0 Windows XP Pro US One of the active network application is "SYSTEM". Process ID 4 UDP 445 TCP 445 TCP 1030 Manufacturer (no information)? The only rule I can create is to block those ports. Is there a way I can find more information about "SYSTEM" (Manufacturer information)? Where in the register I can find more information concerning this application and the ports in use? I want to check if this application is safe? Help appreciated! Greetings, Yves7
- posted
17 years ago
