Hi
The problem i am having is, i have 15 users connect to a SBS 2003 server.
My config is
SBS 2003 with 1 Nic
IP 192.168.0.50 SubNet 255.255.255.0 Gateway 192.168.0.1
DNS 192.168.0.50
Sonicwal IP LAN Side 192.168.0.1 WAN Port connects to ADSL
The is problem is that one 1 clients drops connection to the gateway/sonicwall.
All clients are dhcp and on the same ip range
When i ping 192.168.0.1 i get no reply, but if i ping SBS server
192.168.0.50 i get a reply. I went to another client and tried to ping 192.168.0.1 I get a reply.If i unplug the client with the problem nic cable and put it back in again i get a reply from 192168.0.1, but after a while it drops again. No other user is having any problems.
All the client computers are WIN XP.
I have changed the nic in the client and the cat5 patch lead, but this had made no difference.
This is an intermitting problem, it works then does not work and then it works again.
Any help, advice would be great
Cheers
Niall
