Situation: 2 Computers need to be configured with RD.
I have both setup so that I can access them while on the LAN.
On the WAN, I can access Computer 1.
Computer 2 is supposed to have a second IP on the WAN to port forward the RD requests.
I can't get the second IP to respond on the Sonicwall.
Also, I switched the internal static IPs of the computer 1 and 2, because it was deemed that Computer 2 needed RD sooner.
RD still didn't work on Computer 2, even after the IP switch. I flushed ARP, reset the router (even flashed the router with the latest firmware and reset all settings to factory default). Still it would not pass
3389 to Computer 2. I switched IPs back and Computer 1 works great again.I can't seem to port forward 3390 to Computer 2's IP and translate the port to 3389 or allow Computer 2 to respond to 3390.
It seems like the Sonicwall can't see Computer 2, yet Computer 2 uses the Sonicwall to get tot the internet, the Diagnostics page on the Sonicwall can ping and Traceroute Computer 2, and I can see Computer
2's MAC in ARP.There are several switches on the network, but no other routers. I am not running ISA or any other proxy server.
Any ideas? Both Computer 1 and 2 have firewall disabled.
Thank you,
John
