I have a client that has a pro series sonicwall at their main location and around 100 tz170 sonicwalls at each of the remote locations the tz170 units vpn into the pro unit for dns and to use the content filtering service from the pro unit. they have a web server running on the dmz on the pro unit. the problem is that the remote locations can't view the website from domain.com you can get to the website if you type in its lan ip address. you are able to get to the website if you are not on the network. one of the other guys in my IT department set up dns loopback on the pro unit thinking that mite fix the problem. but it did not solve the problem, so I was wanting to know what else would could be the problem.
- posted
16 years ago
