SonicWall 2040 Login problem
Hello All,
I am attempting to login to our Sonicwall but am told the following:
Login failed - HTTPS User login not allowed from here
This has not been an issue before. I am attempting to login from inside our network, not outside. The UN/P are correct.
Thanks!
AaronS
Am Wed, 20 Jun 2007 06:57:12 -0700 schrieb AaronS:
Hi
Try to connect from another interface which is in trusted mode. Good Luck.
Burkhard Ott
We had a similar problem on our 2040's. You need to make a rule for allowing https to come through you also have to make sure you have checked the remote management checked. Have you called their tech support yet? I've found that they are very knowledgeable.
Hexalon
Am Thu, 21 Jun 2007 23:23:43 +0000 schrieb Hexalon:
I made a totally different experience with their knowledge, they tried to filter IPSec phase2 adresses (encrypted in the esp) with firewall rules but the best they tried that 3h long (I told them before that is technically impossible). If you want I can write you a long list about sonicsupport and knowledge, better is to write a book about it. cheers
Burkhard Ott
