I have a site to site VPN tunnel setup. The network diagram can be found at
There are some issues with the VPN tunnel. One is why can't I ping devices through the tunnel? Also, if I try to telnet into a device from the ASA side to the PIX I am not abel to? I looked on the loggs for the ASA and below is the output. However, if I try to telnet from the PIX side to the ASA side I can telnet but cannot ping. If you need me to post the config for both the ASA and PIX let me know.
Thank You
single_vf %ASA-7-609001: Built local-host inside:10.1.1.4 single_vf %ASA-3-305006: portmap translation creation failed for tcp src inside:10.178.183.68/1025 dst inside:10.1.1.4/23 single_vf %ASA-7-609002: Teardown local-host inside:10.178.183.68 duration 0:00:00 single_vf %ASA-7-609002: Teardown local-host inside:10.1.1.4 duration
0:00:00
