Hi there, I have a single sign on issue using windows xp and internet explorer.
Under normal circumstances, my computer is connected to our local area network. My computer is part of our active directory structure and my username also belongs to the active directory. When I start internet explorer and navigate to our intranet, I will be identified and authenticated by this website via a single sign on mechanism. (With my username, I am logged on with). And everything works fine!
Now assume, that I am on business trip. I am not connected to the LAN and therefore logged on by my cached profile on my computer. (Same username as before). Then I connect my computer to an external provider
by setting up a network connection with an appropriate username and password.
Additionally I set up a VPN tunnel to the LAN of my company.
Now, when I start the internet explorer and navigate to the intranet-web-page, the single sign on fails and I will be promted with an authentication window. And the strange thing is, that the username which is already placed within the form, isn't the username I am logged on with (my cached profile), but the username of the network connection I need to connect my computer to the external provider.
I already did some searches within the filesystem and the registry, but
I nowhere found this username... And I also had absolute no idea, how to configure my windows in the way
to use my username I am logged on with, instead of this username which belongs to the network connection.
I would be more than happy, if somebody could give me a hint... !!!!
Thanks in advance, Josch
