Hi, Recently, I had configured our Fortigate60 (in transparent NAT) to enable public user to access internal web server by using a method call 'port-forwarding' or 'port redirection'. This standalone web server is connected at DMZ port by using different IP addresses (in this case we use 10.1.10.x/24). Another LAN network is using 192.168.1.x/24 addresses. Our Fortigate 60 has only one public IP assigned by our ISP. Our Fortigate60 is using the latest firmware version 2.80.
I unable to access our internal web server from outside eventhough I had configured it to do 'port-forwarding'. I had checked my firewall policies and found nothing wrong with it. There's no problem for internal LAN users to surf and they are able to access web server with no problem, except for public user. How to solve this problem? Did I make a mistake in configuration? Thanks in advance.
Regards. Alex
