I do not know if this helps but this is the web page at the Linksys WRT54G router page "Status -> Router" https://192.168.0.1/StaRouter.htm
A:hover { COLOR: #00ffff } .small A:hover { COLOR: #00ffff }
var refresh_time = ""; var flag=0; function DHCPAction(F,I) { F.action.value=I; F.submit(); }
function ConnStats(obj) { var F=document.status; if(flag == 1){ F.action.value="Connect"; } else{ F.action.value="Disconnect"; } F.submit(); }
function GetWAN() { var F=document.status; var wan_num=F.wan_pro.value; if(wan_num==2){ if (((F.conn_stats.value=="-1")&&(status2!="Connecting"))||((F.conn_stats.value=="201")&&(status2!="Connecting"))||((F.conn_stats.value=="202")&&(status2!="Connecting"))||((F.conn_stats.value=="203")&&(status2!="Connecting"))||((F.conn_stats.value=="200")&&(status2!="Connecting"))){ flag = 1; F.butConn.value=stacontent.connect; } else{ F.butConn.value=stacontent.disconnect; flag = 0; } } else if((wan_num==3) || (wan_num==4) || (wan_num==5)){ if((F.conn_stats.value=="-1")&&(status2!="Connecting")){ flag = 1; F.butConn.value=stacontent.connect; } else{ flag = 0; F.butConn.value=stacontent.disconnect; } } } function ShowAlert(M) { var str = ""; var mode = ""; /* */ var wan_ip = "69.110.22.230";
if(document.status.wan_pro.value == 2) mode = "PPPoE"; else if(document.status.wan_pro.value == 3) mode = "PPTP"; else if(document.status.wan_pro.value == 4) mode = "L2TP"; else if(document.status.wan_pro.value == 5) mode = "HBS"; else mode = "PPPoE";
if(M == "AUTH_FAIL" || M == "PAP_AUTH_FAIL" || M == "CHAP_AUTH_FAIL") str = mode + stacontent.authfail; else if(M == "IP_FAIL" || (M == "TIMEOUT" && wan_ip == "0.0.0.0")) str = stacontent.notgetip + mode + stacontent.wansrv + stacontent.wansrvlastwords; else if(M == "LCP_FAIL") str = mode + stacontent.lcpfail; else if(M == "TCP_FAIL" || (M == "TIMEOUT" && wan_ip != "0.0.0.0" && (document.status.wan_pro.value == 5))) str = stacontent.notcpconn + mode + stacontent.wansrv; else str = stacontent.notconn + mode + stacontent.wansrv;
alert(str);
Refresh(); } var value=0; function Refresh() { if(refresh_time == "") refresh_time = 60000; if (value>=1) { window.location.replace("StaRouter.htm"); } value++; timerID=setTimeout("Refresh()",refresh_time); } function ViewDHCP() { dhcp_win = self.open('DHCPTable.htm','inLogTable','alwaysRaised,resizable,scrollbars,width=720,height=600'); dhcp_win.focus(); } function init() { var F=document.status; var wan_num=F.wan_pro.value; if((wan_num>=2) && (wan_num =2) && (document.status.wan_pro.value document.write("
