Script to disconnect Linksys WRT54G wireless router on Windows
Threaded View
Is there an existing wireless router linksys WRT54G script out there that
will run from Windows XP and hit the 'connect' & 'disconnect' button?
For example, I'd like to disconnect my wireless router (firmware 1.02.0) by
clicking on a single shortcut to replace the multiple button presses today.
That shortcut would (perhaps using wget or some other idea):
1. Connect to the wireless router IP address (https://192.168.0.1 )
2. Log in with a blank username & enter 'letmein' as the password
3. Navigate to the "Status -> Router" Linksys WRT54G web page
4. Press the "Login Status = Disconnect" button
A similar shortcut would reconnect on demand.
Is "wget" the best way to accomplish this?
I can't believe I'm the first person to need this so some kind wireless guy
must have done this already. I googled for "linksys wrt54g connect script"
and found something called "slackware" in addition to "wget" but I'm not a
programmer so I would like to start with an existing script that does
SOMETHING like hit any button on the Linksys WRT54G router. Once I have
that, I can probably modify that program to do what I want.
I did find http://www.seattlewireless.net/index.cgi/LinksysWrt54g
interesting but I did not understand most of the detail (I have a lot to
learn).
Does anyone have a script that runs on windows that will connect to
https://192.168.x.y to then hit a button on the Linksys WRT54G router?
Re: Script to disconnect Linksys WRT54G wireless router on Windows
Hi
Routers are propriety devices there is No one universal way to control them.
As a result you cab expect Windows as an OS to be programmed to control
every Independent 3rd party device.
If it really important you can learn simple scripting, or pay some one to do
it.
If you just want to disconnect a computer from the Router you can use the
IPCONFOG /release command.
http://www.ezlan.net/iprel.html
Jack (MVP-Networking).
Hi Jack,
I want to disconnect the router from the isp (not the pc from the router).
I dug some more and have some perl scripts (whatever perl is) and will see
if they will run on Windows.
Apparently they need to know the name of the Linksys WRT54G button. I
viewed the page source at https://192.168.1.0/StaRouter.htm and I think
that the button is called "connect" and then "disconnect".
I'll keep digging and asking questions and posting the answers as I find
them until we have a Linksys WRT54G script that runs from Windows to
a) Log into the Linksys WRT54G router
b) Navigate to the https://10.2.18.20/StaRouter.htm page
c) Press the disconnect button
d) Wait five or ten seconds
e) Press the connect button
This refreshes with a new IP address.
Pathologically Eclectic Rubbish Lister
Sure.  There are several Windoze "automation" tools.  The one I like
to use is the ancient "Macro Recorder" from Windoze 3.1.  However, I'm
not going to recommend this because of its age.
More modern incantations can be found at:
<http://www.kratronic.com/recorder/ ($23)
<http://www.aldostools.com/macro.html
<http://www.jitbit.com/macrorecorder.aspx
and so on.  Search Google for "macro recorder" or "keystroke mouse
recorder".  Lots to choose from.
You start the recorder, do whatever it takes with your mouse and
keyboard, stop the recorder when done, and save the macro.  If you
want to repeat it again, just run the macro.  Simple.
Another way to do this is to install DD-WRT or OpenWRT on your WRT54G,
and use various shell or expect scripts to turn the router on and off.
The command to turn on/off the WAN connection could be:
  ifconfig eth1 up
  ifconfig eth1 down
or something like that.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Hi Jeff,
I know from googling that you are a God on this here newsgroup so I
appreciate your help even if I'm not quite sure how to install "DD-WRT".
I'll look it up and hopfully post an answer so the next guy can press a
button to log into the Linksys WRT54G router, navigate to the status router
page, press the disconnect button, wait five seconds, press the connect
button.
This will automatically get a new IP address (at least in my setup it does
when I do this manually).
How to install DD-WRT:
<http://www.dd-wrt.com/wiki/index.php/Installation
Note that there are different firmware images and proceedures for the
various WRT54G hardware versions.  You didn't specify yours.  Check
the serial number label.
I believe I suggested a method using a "macro recorder".
Maybe.  Most ISP's don't work that way.  If you disconnect, the next
time you reconnect, you'll probably get the same IP address.  That's
to keep their log files sane.  Notable exceptions are the ISP's that
change IP addresses to discourage setting up servers.
I question why you would need to change IP's?  If this is some
variation on trying to become anonymous or hidden while on the
internet, you're on your own.
I'm not a Perl programmer, so I can't help you learn Perl via usenet.
Hi Jeff,
Do you think this perl script modified to hit the disconnect & connect
button will work? I'm googling for just how I would change the script
below.
So far, I see the following changes needed:
1. I will google to see how to give the "null" set (blank?) as a login
2. I need to figure out how to press the disconnect button
Before I dig further, is this script below a good place to start in order
to create a Windows script that disconnects the Linksys WRT54G wireless
router from the ISP from a wireless portable PC client?
Wilson
#!/usr/bin/perl -w
use strict;
# check out this documentation:
# first, the cookbook
# http://search.cpan.org/~gaas/libwww-perl-5.805/lwpcook.pod
# the LWP reference
# http://search.cpan.org/~gaas/libwww-perl-5.805/lib/LWP.pm
# oh but this is JUST what we want
# http://lwp.interglacial.com/ch05_05.htm
my $adr='https://192.168.0.1/Services.asp '; # talk to this
my $user='root';
my $pass='letmein';
# make a User Agent
use LWP::UserAgent;
my $ua = LWP::UserAgent->new;
# make a request object
# fill in the button name and value from
# looking at the page source.
# DD-WRT puts out a complicated page with Javascript that
# I don't understand how to deal with, so this doesn't work,
# but in principle (if I knew what to put in for action and reboot)
# it should.
my $req = HTTP::Request->new(POST => $adr,
                 ['action','reboot']);
$req->authorization_basic($user, $pass);
# send the request
my $result = $ua->request($req);
# print the result
print $result->as_string;
Bearing in mind I don't know perl, in the previous perl script to press the
disconnect button on the Linksys WRT54G router ... do these changes seem
correct to you perl programmers?
1. Log in from Windows to the Linksys WRT54G router with a blank username
and a password of "letmein".
INSTEAD OF:
I WOULD USE:
my $user='';
 $pass='letmein';
2. Navigate to the Linksys WRT54G "Status -> Router" web page.
INSTEAD OF:
I WOULD USE:
my $adr='https://192.168.0.1/StaRouter.htm '; # talk to this
3. Press the disconnect button on that Status->Router web page.
INSTEAD OF:
I WOULD USE:
                  ['action','disconnect']);
4. Reconnect after a period of time, say 5 seconds.
INSTEAD OF:
I WOULD USE:
-----                 ['action','connect']);
Since I don't know perl (nor even how to run perl on Windows XP), I wish to
ask before trying to see if the approach seems like it will work for you.
Meanwhile, I'll try to get the script to work (so far, when I click on my
modified script, see below, it just brings up Notepad).
Wilson
#!/usr/bin/perl -w
use strict;
# the LWP reference
# my $adr='https://192.168.0.1/Services.asp '; # talk to this
my $user='';
# my $pass='mypassword';
my $pass='letmein';
# make a User Agent
use LWP::UserAgent;
# it should.
# my $req = HTTP::Request->new(POST => $adr,
#                            ['action','reboot']);
# I need to figure out how to wait 5 seconds in perl; then reconnect
# send the request
# print the result
# The end of a perl script to run on Windows to tell the Linksys WRT54G
# router to disconnect from the ISP; then after 5 seconds, to reconnect.
It's not working yet - but it's closer than it was
Here is the tutorial so far.
STEP 1:
Install ActiveState activeperl freeware on Windows XP
http://www.activestate.com/Products/activeperl
STEP 2:
Modify script to use YOUR password for your Linksys WRT54G router review
STEP 3:
Run script
At this point, I get the following error.
I will google for this package and see if I can find it on the web.
501 Protocol scheme 'https' is not supported (Crypt::SSLeay not installed)
Content-Type: text/plain
Client-Date: Wed, 21 Nov 2007 01:22:38 GMT
Client-Warning: Internal response
LWP will support https URLs if the Crypt::SSLeay module is installed.
More information at <http://www.linpro.no/lwp/libwww-perl/README.SSL .
Wilson
#!/usr/bin/perl -w
use strict;
# my $user='root';
my $user=''; # the Linksys WRT54G wireless router doesn't have login name
my $pass='letmein';
# make a User Agent
use LWP::UserAgent;
my $req = HTTP::Request->new(POST => $adr, ['action','disconnect']);
sleep 5;
my $req = HTTP::Request->new(POST => $adr, ['action','connect']);
# send the request
# print the result
Here is my tutorial to press buttons on your router from the Windows
command line.
It's not working yet because I don't know how to modify the perl script to
load the Win32 OpenSSL package I installed in order to talk to https web
site.
Does anyone know what line to add to the script below in order to load the
Win32 OpenSSL freeware?
Wilson
How to command your router from the Windows command line:
0. Install ActiveState activeperl freeware on Windows XP
1. Install Win32 OpenSSL freeware support for https URLs
   http://www.openssl.org/related/binaries.html
2. Add the following line to the perl script to load openssl
   ???? what is the line needed to load Win32 OpenSSL????
3. Modify the script to press desired buttons on your router
#!/usr/bin/perl -w
use strict;
# Linksys WRT54G Router automation button pressing script
# Read the cookbook
# Read the LWP reference
# Read this too
# my $adr='https://192.168.0.1/Services.asp '; # talk to this router
my $adr='https://192.168.0.1/StaRouter.htm '; # talk to this router
# my $user='root';
my $pass='letmein';
# make a User Agent
use LWP::UserAgent;
# fill in the button name and value from looking at the page source.
# my $req = HTTP::Request->new(POST => $adr, ['action','reboot']);
# A view source on the browser web page seems to indicate the disconnect
# button is named "disconnect" so I'll substitute that instead of "reboot".
# Wait five seconds and then run the next command
sleep 5;
# send the request
# print the result
Under ActivePerl you can install Crypt::SSLeay with
    C:\\> ppm install http://theoryx5.uwinnipeg.ca/ppms/Crypt-SSLeay.ppd
    use warnings;
is better than -w nowadays.
Huh? You surely want to do something with this request, like submit it
to $ua?
Ben
Hi Ben,
Your suggestion is very helpful as I was clueless as to the next step.
I hope to write up a short tutorial to help others, so, in the spirit of
the tutorial, here is the output from your suggested "ppm" command
(whatever that is)...
I'm not sure what I just did, but a lot happened when I ran:
See below for the log file.
Wilson
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
Syncing site PPM database with .packlists...done
Downloading Crypt-SSLeay-0.53...done
Unpacking Crypt-SSLeay-0.53...done
Generating HTML for Crypt-SSLeay-0.53...done
Updating files in site area...done
Downloading Crypt-SSLeay-0.53 install script...done
Running Crypt-SSLeay-0.53 install script...
This software package uses strong cryptography, so even if it is created,
maintained and distributed from countries where it is legal to do this,
it falls under certain export/import and/or use restrictions in some
other parts of the world.
PLEASE REMEMBER THAT EXPORT/IMPORT AND/OR USE OF STRONG CRYPTOGRAPHY
SOFTWARE, PROVIDING CRYPTOGRAPHY HOOKS OR EVEN JUST COMMUNICATING
TECHNICAL DETAILS ABOUT CRYPTOGRAPHY SOFTWARE IS ILLEGAL IN SOME PARTS
OF THE WORLD. SO, WHEN YOU IMPORT THIS PACKAGE TO YOUR COUNTRY,
RE-DISTRIBUTE IT FROM THERE OR EVEN JUST EMAIL TECHNICAL SUGGESTIONS
OR EVEN SOURCE PATCHES TO THE AUTHOR OR OTHER PEOPLE YOU ARE STRONGLY
ADVISED TO PAY CLOSE ATTENTION TO ANY EXPORT/IMPORT AND/OR USE LAWS
WHICH APPLY TO YOU. THE AUTHORS OF OPENSSL ARE NOT LIABLE FOR ANY
VIOLATIONS YOU MAKE HERE. SO BE CAREFUL, IT IS YOUR RESPONSIBILITY.
CREDIT INFORMATION: This product includes cryptographic software
written by Eric A. Young (eay@cryptsoft.com). This product
includes software written by Tim J. Hudson (tjh@cryptsoft.com).
Proceed with installation? [yes]
A copy of the needed library ssleay32.dll was found in
C:\\WINDOWS\\system32\\ssleay32.dll.
If this is compatible with the version (0.9.8a)
used to compile the Perl module, all that is needed to
complete the installation is to ensure
C:\\WINDOWS\\system32\\ssleay32.dll is in your PATH environment variable.
Fetch ssleay32.dll? [no]
Aborting download of ssleay32.dll.
done
  13 files installed
C:\\>
[f'ups to clpm]
'ppm' stands for 'Perl package manager'; it is a utility which comes
with ActivePerl for installing Perl modules. If you run it with simply
'ppm' you'll get a GUI you can use to locate and install modules.
The reason for the complete URL (rather than simply 'ppm install
Crypt-SSLeay') is that ActiveState's repositry is located in Canada, so
they aren't allowed to provide cryptographic software without a license.
theoryx.uwinnipeg.ca is an alternative repositry which contains the
crypto modules most people need.
Everything seems to have happened as it should. You can test it has
installed correctly with
    perl -MCrypt::SSLeay -e1
which should give no output.
This is saying you already have ssleay32.dll on your system. If you want
to use this copy instead of downloading a new one, you need to be sure
it is the correct version (0.9.8a), which you can probably check from
the Properties window in Explorer, and you need to be sure it is in your
PATH so perl can find it (system32 is already in your PATH, of course).
Here ppm is offering to install a new copy of ssleay32.dll; since you
already have one, the default answer is no. Had you said 'yes' it would
have downloaded a new copy and put it somewhere perl could find it.
The installation was successful.
Ben
Hi Ben,
I'm pretty confused about this part as I do not know Perl.
The original script I found googling did a "reboot" of the router.
I modified that original script to attempt to do a "disconnect" and then
five seconds later to do a "connect" (assuming I have the name of the
buttons correct for the Linksys WRT54G wireless router).
Here is the original script, in its entirety.
Does this original script perform "something" with the request?
Wilson
#!/usr/bin/perl -w
use strict;
# the LWP reference
my $user='root';
my $pass='mypasswd';
# make a User Agent
use LWP::UserAgent;
# it should.
# send the request
# print the result
Well, I didn't get any results back yet and it's still not working but I'll
keep trying things .....
C:\\freeware\\perl>router.pl
500 Server closed connection without sending any data back
Client-Date: Wed, 21 Nov 2007 06:10:15 GMT
Here is the tutorial so far ....... (note it doesn't work yet) ......
All I'm trying to do is disconnect and reconnect using a command line
script.
Any and all help for this tutorial is appreciated as this is my very first
perl program ever.
Wilson
How to control your wireless router from the Windows command line
0. Obtain the basic Perl script to reboot the Linksys WRT54G:
   (see sample Perl script below)
1. Install ActiveState activeperl freeware on Windows XP:
   For example, install the msi file into c:\\freeware\\activeperl
2. Install "Crypt::SSLeay" under ActivePerl using ppm commands:
    c:\\> cd c:\\freeware\\activeperl
    c:\\> ppm install http://theoryx5.uwinnipeg.ca/ppms/Crypt-SSLeay.ppd
3. Install Win32 OpenSSL freeware support for https URLs
   For example, install into c:\\freeware\\activeperl\\win32openssl
4. Make sure both Perl is in your Windows PATH shell variable:
    Start Settings Control Panel System Advanced
    Environment Variables System variables Path
5. Test Win32 OpenSSL on Windows from the command line:
    c:\\> openssl version [hit Enter]
    c:\\> openssl s_client -connect www.openssl.org:443 [hit Enter]
    GET / HTTP/1.0 [hit Enter twice]
6. Modify this script to press desired buttons on your router
#!/usr/bin/perl -w
use strict;
# the LWP reference
my $user='root';
# make a User Agent
use LWP::UserAgent;
# it should.
# send the request
# print the result
7. Here is a modified script intended to disconnect & reconnect:
#!/usr/bin/perl
use strict;
use warnings;
# the LWP reference
# my $user='root';
my $pass='letmein';
# make a User Agent
use LWP::UserAgent;
# it should.
# Wait 5 seconds - then reconnect as this will get you a new IP address
sleep 5;
# send the request
# print the result
Any idea how to debug this shortened freeware Perl script to disconnect the
Linksys WRT54G wireless router from the ISP? The Perl script just hangs
without any output or change in the router. Is there a way to insert debug
statements or to step through the Perl code using freeware debuggers on
Windows?
Here is, I think, the related "view -> source" code on the router at the
web page: https://192.168.0.1/StaRouter.htm
function ConnStats(obj)
    var F=document.status;
    if(flag == 1){
        F.action.value="Connect";
    else{
        F.action.value="Disconnect";
    F.submit();
And, here is the shortened perl script using "Disconnect" as the action:
#!/usr/bin/perl -w
use strict;
# my $user='root';
my $user=''; # the Linksys WRT54G wireless router doesn't have a username
my $pass='LetMeIn';
use LWP::UserAgent;
my $req = HTTP::Request->new(POST => $adr, ['action','Disconnect']);
# send the request
# print the result
# The end
Unfortunately, when I run this router.pl script on Windows, it just hangs.
Do you have any suggestions for debugging this on Windows?
I thought the script hung but it just took a while to output this.
500 read failed:
Client-Date: Wed, 21 Nov 2007 13:32:50 GMT
500 read failed:
Do you have any suggestions for debugging freeware WIndows perl scripts?
I think I'm going to have to give up as there just seems to be no way that
any perl script can press any button on a linksys WRT54G router based on
all my hundreds of failed attempts and the lack of any successful perl
scripts on the Internet.
Advice for the next guy: Be forewarned; you can't press a button on a
Linksys WRT65G router using Perl. Some other approach might work; but not
Perl.
What nonsense. You said yourself that you're not a programmer and don't know
Perl - what makes you think that something is impossible simply because *you*
can't figure it out?
sherm--
WV News, Blogging, and Discussion: http://wv-www.com
Cocoa programming in Perl: http://camelbones.sourceforge.net
Site Timeline
